Question about Samsung SyncMaster 730MW 17" Flat Panel LCD Monitor
My Syncmaster 730mw keeps losing its picture afer a few seconds. No matter which input I use VGA, SCART, Component the picture comes up crystal clear and then flicks off after about 1 - 2 seconds! I can hear sound but no image, if I look closely I think I can make out the menu screen. Is this an intermittent backlight issue? Can it be easily fixed?
  • Samsung Master
  • 32,281 Answers
If you can make out a faint image then the fault is a backlight problem.
The fault could be an inverter board or the CCFL lamp/s
For service, parts and DIY info check out LCD Parts - click on this link to their WEB site : -
www.lcdparts.net
Posted on Oct 19, 2009
6ya staff
SOURCE:
My syncmaster 730MW used to take some mins before coming on..then it got to an hour, now it gone of completely what do i do?
> what do I do ?
Spend $50 to $100 at any TV/video repair-shop, for trouble-shooting and repair.
Or, spend $40 to $50 to buy a used 17-inch LCD screen, or $100 to buy a new 19-inch LCD screen.
Feb 17, 2011 | Samsung SyncMaster 730MW 17" Flat Panel...
Do i need a converter box for a samsung syncmaster 940 mw
It depends. What are you using the monitor for? If you want to watch digital TV, you need a digital to analog converter. (It has an NTSC tuner.) Note: the digital to analog converters that were subsidized by the US government coupon only gave SD out.
If you are connecting to a PC, it has DVI-D (21 pin SCART) and VGA connections (15 pin SCART). (An HDMI to DVI cable or adapter would connect to HDMI video cards.) Most other set-top boxes will connect to the component, composite or S-video connectors.
I hope this helps.
Jan 07, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
The screen will not come on
i think lose power
i hope i can solve your problem
Sep 02, 2009 | Samsung SyncMaster 730MW 17" Flat Panel...
Connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Jan 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Optoma EP716 cycling through inputs problem
reset the settings on the projector to factory default.
Dec 15, 2008 | Office Equipment & Supplies
Acer Picture in Picture Problems - Can't Change it off VGA
yes your keypad is locked to open it you press all keys on monitor simultaneusly for 5 seconds window wll show massage keypad unlocked then release window will dissapear
Oct 29, 2008 | Samsung SyncMaster 940MG 19" LCD Monitor
Samsung SyncMaster 730MW 17" Flat Panel LCD Monitor Logo
225 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
