Posted on Dec 29, 2007
Ilo mp-556 Plugged in and installed. I have XP and media 10. Trying to sync and media 10 says no device detected?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Dec 30, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
372
Points
Same happened to me i had to buy a new sd cable for mine and it worked for me it should work just fine after that
1helpful
2answers
Compatibility of sd and sdhc
no this device is SD and MMC only
http://www.amazon.com/iLo-Player-Cherry-MP-556-MP556/dp/B0018ZA2V8
Check your spec, sorry
Regards
Richard.
3helpful
2answers
ILO MP-556 MP3/WMA player
Revised iLo instructions for Windows Media Player 11:
Connect the iLo to the computer
In Windows Media Player 11, Run the mouse over the Sync tab
Click the little black arrow that appears underneath the Sync tab
Select More Options
Click the Devices Tab
Highlight the iLo
Click Properties
Uncheck box, "Create Folder Hierarchy on Device"
Download the firmware file at: https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip
then proceed with the rest of the directions
-Tha Mp3 Doctor
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connectedâ€
. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
Ilo mp 556 is not reconized
Hold/lock is engaged
Rest the player
Ilo mp3 player model mp-556
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
2answers
Ilo 1GB Mp3 Player Only had for a month and quit working properly
YOU HAVE TO SYNC THROUGH MEDIA PLAYER - IT DOES NOT RECONGIZE SONGS IF YOU JUST COPY THEM ONTO THE SD CARD.
FOR VISTA -This player only seems to be able to transfer MP3 format with Vista, using windows media player syne. Unless someone found otherwise.
FOR XP PRO When using XP Pro and Windows Media Player you can transfer WMA but you have to go into the PROPERTIES of the drive (mine was mp-556/G: drive) and DESELECT the option to transfer FOLDER HEIRECY. The MP3 player is not able to reconginize the folder structure it usually creates by default.
2answers
Ilo mp3 Player Model MP-556
I just got an ilo mp3 player and when I try to sync songs from Windows Media Player 11 to it, it only puts about 1/2 of the songs on it. It says it has plenty of memory, so what's the problem?
...Ditto >.>
Ilo mp3 player 1g
When using XP Pro and Windows Media Player you can transfer WMA but you have to go into the PROPERTIES of the drive (mine was mp-556/G: drive) and DESELECT the option to transfer folder hierecy. The MP3 player is not able to reconginize the folder structure it usually creates.
2answers
Delete
when you pull up your music delete it on the computer while the mp3 is plugged in
3helpful
3answers
MP-556 MP3/WMA PLAYER
http://www.lenoxx.com/2005/mp3player/mp556.htm if you have a ilo model mp-556 (on the back cover) this page has links to the firmware ... i follow the instruction and got mine working.
1helpful
Problem with songs
http://www.lenoxx.com/2005/mp3player/mp556.htm if you have a ilo model mp-556 (on the back cover) this page has links to the firmware ... i follow the instruction and got mine working. u might need to use the reformat as well as the upgrade firmware to make your list read the same. reformating will set your storage area back to factory specs. i e delete all your songs on your player
Top iLO Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
k24674
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
