HP Photosmart 2710 All-In-One InkJet Printer Logo
Posted on Oct 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I get error codes 0x887ffd78 & 0x6b900004b when I attempt to print a document. -hp photosmart 2710 -wireless network
Anonymous
Level 2:
Sergeant:
  • Expert 194 Answers
  • Posted on Oct 19, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
194
Questions
0
Helped
57451
Points
534
There something wrong with the installation of your software printer...
install again so that the error appear will not come back more
We are the suppliers for HP printers/copiers in Samoa and we are currently having problems with as HP Photosmart wireless multifunctional printer. The error message 0x6100004c keep on appearing even though...
Here is a support document on how to resolve printer errors: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&cc=us&lc=en&dlc=en&product=4186830&tmp...
If you are able to attempt printing from the wireless network, and the printer is making noise like it is trying to print then you are successfully connected to the network. If the printer is not even attempting to print then the printer may be offline. Click on the start menu and then select the printers and faxes, or the printers and devices folder. Right click on the printer name and select "use printer online". If the printer is already online open the printer queue and look to see if there are any errors for the print job. Normally if the message is saying there is a paper issue, you can remove all the paper from the printer, shut down the computer and printer, reload the printer with paper, and then restart the computer and printer.
Below are some links to HP printer manuals
Links to HP Manuals:
http://www.retrevo.com/samples/HP-Printer-manuals.html
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&prodSeriesId=1845551&prodTypeId=18972
http://office.manualsonline.com/manuals/mfg/hewlettpackard_1/hewlettpackard_1_printer_product_list.html
There are multiple locations where you can get manuals for HP printers/copiers
HP Photosmart 2710 Scaning software
The software for the HP Photosmart 2710 All-In-One InkJet Printer can be found at
http://www.hp.com/#Product
After arriving at the site, click on the subheading "Support & Drivers", then follow the 2 steps
listed to obtain the needed software.
Hp photosmart 7200 and hp laptop are not communicating. wierless signal strengh is excellent. cancelled , documents cancelled and error message appears.
Click on the link to resolve printing issue on wireless network -> Link
Click on the link to find out if the HP Printer is on wireless network on not -> Link
To Setup the printer on wireless network, follow the steps below
1. Press the SETUP Button printer front panel
2. Scroll to Network - Press OK
3. Scroll to Wireless Setup Wizard - Press Ok
The printer will start searching for wireless router.
Choose the SSID ( Network ) and enter SSID ( network key if setup ) and Press OK
You should get a message as Printer Wireless Setup complete.
Run the HP Printer Software Disk and Choose Add a printer and Choose Wireless Installation and follow the instructions on the screen to complete the setup
You are ready to Print and Scan
I was printing a document when the printer stopped and this error popped up on the printers LCD (hp photosmart 2710) ''remove and check right ink cartridge'' how do I fix it?
1. your rt side ink cartridge is damaged change it with compatible or new cartridge to get rid from this error.
2. or try ones cleaning the cartridge with dry cloth.
Wireless HP 6180 PhotoSmart All in ONe will not scan document to my computer
Well its the issue with the printer drivers taking a dynamic ip address.all you need to do is uninstall the printer network drivers,insert the s/w cd that came with the printer and then click on add a device ,it would install the printer drivers all over again.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
I can print wirelessly but when I try to scan, it says that I need to downloan HP software. But didn't I do that already?
you may have to remove the latest HP All-in-One software then re-install it again.. you can download it from this link, http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=420428&
if you have Mac OS X - this might be helpful,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01396146&lc=en&dlc=en&cc=us&product=420428&rule=12094&lang=en
Printer will not print wireless
my 2710 HP printer prints every thing fine from all the other programs but it does not print sheet from excel program any one can help?
really appriciate it
thanks,
Ray
2helpful
2answers
HP 2710 All in One Printer/Scanner/FAX and Vista
There are two models of printers starting with the number indicated. Both have Vista drivers and both have documented vista installation issues. Using the following link
HP Photosmart 2710
Select the correct model
Under software and downloads you will find the software necessary.
Below that you will see a link for Trouble Shooting software ...
Click it then Windows Vista and you will see two potential installation issues you may encounter.
k24674
Grand Canyon Tech
Grand Canyon Tech
