A squealing noise during the sensing cycle of your Maytag top-load washer can be caused by a number of factors. Here are some common reasons and steps you can take to resolve the issue:
Loose belt - The noise could be caused by a loose or worn belt that needs to be tightened or replaced. You may need to remove the front panel of the washer to access the belt.
Idler pulley - If the idler pulley that keeps tension on the belt is worn or damaged, it can cause a squealing noise. Replace the idler pulley if necessary.
Bearing - A worn bearing in the tub can cause a squealing noise. Replacing the bearing will typically require disassembling the washer.
Drive motor - If the drive motor is worn or damaged, it can cause a squealing noise. Replace the drive motor if necessary.
If you're not comfortable diagnosing and repairing the issue yourself, it's best to contact a qualified appliance repair technician for assistance.
Top Loader? That sounds like a gearbox problem. It is not an easy fix. With that much use and those many years, it is probably time for a new one. A new High Efficiency Front Loader, will save you a fortune in water, electricity and detergent.
Try this forum though if you want to try and get it fixed.
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
Yes it could most likely be the idler pully mounted in photo as part 38 Click Here=> Maytag MGD6300T Gas Dryer Part 38 is your dryers Idler & Pulley Assembly Part Number Click Here=> 8547174 There is no photo for that link but that is the OEM part number. When the bearings fall out of the pulley this begins a cycle of from bad to the belt (39 in photo) part number Click here=>Belt, Drive 8547168 Should you have more questions please ask, Thanks, Sea Breeze.
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
First, pop up the top of the dryer -- use a large slotted screwdriver under each corner of the top. There will be screws holding the front of the dryer -- take these out and take the front off. The squealing is coming from roller bushings which need lubricating. Apply machine oil to all the axles/bushings -- this most likely will stop the squealing -- and don't forget to unplug it first.
A little lubricant on the pulleys near the belts will go along way. Its very easy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
