Vizio VW42LF 42 in. LCD HDTV Logo
Posted on Oct 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv has blue/white lines going through the screen after it has been turned on for awhile. turning the tv off and then on sometimes fixes the problem for awhile. The TV also goes blank and then comes back on. It also goes blank and then snowy and then blue. This is VIZIO vw42lf tv
Chi Chu
Level 3:
  • Vizio Master 8,457 Answers
  • Posted on Oct 19, 2009
Chi Chu
Vizio Master
Level 3:
Answers
8457
Questions
0
Helped
2822610
Points
26282
Ur main video board backlight,is dying must be replace to solved this prob.
Purple and blue screen on dlp tv
Sounds like a problem with the Vertical Video Card.
Have fun finding one. If your TV is still under warranty... send your TV off for repair.
LCD displays 4 white lines and has double vision
I saw your tv pictures at above mentioned website link.
It is LCD Panel (screen) problem, call Sony and ask for warranty cover to replace lcd panel.
Thanks.
PS3 Blue Ray White lines on left side of TV
I have the same TV, and a Sony BluRay player (not a PS3). I have the same problem.
I found it only does this when playing back 24p disks. My player has an option to disable 24p output to the HDMI, and it "fixes" the problem.
Not really a fix, but a workaround.
Not sure whether it is the TV or player, and sometimes I have fixed it by turning the tv off and on multiple times.
I am going to test the player on another monitor and see if it does the same thing. If so, the player is going back to the store.
Insignia NS-PDP32-09 Purple Dots
Its hard to say this but your tv has a bad PDP Panel unfortunately the panel is not available for the tv. If not in warranty see if your home owners insurance will cover it.
2 yr old Samsung Television screen lite blue wiht white lines
your television is going to need an internal repair. most likely in the power supply of the television. it would be best to unplug the television until it can be repaired. If you would like to repair the television yourself then please use our premium service so an expert can walk you through it. Or you can search for a local repair service using our local repair search engine.
Please help
I suspect if you have green lines .you have a bad crt. there are three tubes red green and blue i suspect blue tube. tubes cost is around 300.00 to fix.
thanks doctor video
note sometimes you could adjust screen voltage located near the front grill black box . becareful high voltage ony a pro should do.
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
2answers
Blue screen of death on a tv??
this could be three differnt things
1. the crt itself could be bad
2.the vertical ic on the crt board
3. the focus pack or focus block
1helpful
Panasonic tv has white lines at top of screen
suspect it's 1 or a couple of bad capacitors in the vertical deflection circuit the caps are in the 400 series, c400,c401,c402, etc... check or replace c414,c418 & c417
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
