Yardman snowblower Regency 13hp 33'' 31AE993I401 will not shift into hi-reverse. Outside 90deg shifting arm is bent towards rear. Is problem likely just the arm or might it be internal?
You must been the arm back. look under your unit and check the drive rubber wheel. your are going to probably need to adjust the shift arm assay. make sure you lube all slide shafts. let me know
Testimonial: "Inherited snowblower w/bent shift lever. Easy job to remove back cover - dry shaft but more interesting - full of a mouse nest - great now, thanks!"
