Got my father a garmin 76csx for christmas and its the first one we ever owned, He wants to be able to measure his land/acres because he seen it done on one a friend of his had (which I dont think was garmin).
my question is can you help me with detailed instructions on how to accomplish this in Canada, Ontario?
Instruction manual is like chinese to us
thanks
SOURCE: My instruction manual for my Garmin nuvi 205W
Yes, Here is the link. 5th item download from the top.
http://www8.garmin.com/products/manual.jsp?product=010-00718-40
- Jim
SOURCE: Need instructions for garmin 255w
Please use this link. The manual for the 205W will work just fine for you.
https://buy.garmin.com/shop/store/manual.jsp?product=010-00718-20&cID=137&pID=13431
- Jim
SOURCE: No instruction Manual
Here's the URL, from which you need to select "Owner's Manual":
http://www8.garmin.com/support/userManual.jsp?market=4&subcategory=41&product=010-00657-20
If it doesn't work, navigate this way:
Go to www.garmin.com
From the menu, select Support | Manuals
In the dropboxes, select: Mobile Electronics, Automotive,nuvi 750 then "Show Me"
SOURCE: My sons Garmin nuvi 360 has just stopped acquiring
Try resetting everything. The first step is to Start the GPS unit, while it is starting (when the screen turns on) hold your finger in the lower left corner. It will then prompt you to open in maint. mode. Select yes, and go through the menus by selecting next. When a third option is shownsuch as reset, select it. Reset everything including deleting your saved addresses, you will loose all of your saved info but it should start working again. Hope this works for you as it did for me.
SOURCE: I do not have an instruction manual and would like to buy one.
Please see this link to download the manual (4th item down). Please rate my solution as fixya if my solution helped you.
https://buy.garmin.com/shop/store/manual.jsp?product=010-00575-10&cID=137&pID=13430
- Jim
SHARCNET-USA
