Servtek06 writes:
check connections @ control board/module. May be Control Board/Module.
There are design problems with certain model dishwashers where the wire gauge on wire harness was too small and would heat up causing the thermal fuse to blow prematurely. The replacement kit includes a wire harness with a thicker gauge wire, preventing the fuse from blowing prematurely. There were no reports of fire hazard.
The problem with the unit is the thermal cut-out/fuse has tripped. You'll need to purchase the replacement kit #959376. It should be available at most local parts retailers, or online parts depots as well. (double check with your model number, but that is the most common)
**Be sure to use the entire kit**.
You'll notice there are new wires to the fuse to be spliced into existing ones, this is to ideally prevent the problem from re-occuring. (follow the instructions provided, you'll be fine)
If the problem does re-occure in the near future, you'll need the control, #1060952
hope that helps,
Good Luck
