Sony Playstation 3 (PS3) Console Logo
Posted on Oct 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I got my new samsung series 5 tv yesterday and had the ps3 working, then it had a green screen and now the tv wont come out of what appears to be standby mode
Anonymous
Level 2:
Novelist:
  • Expert 149 Answers
  • Posted on Oct 28, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
149
Questions
0
Helped
27079
Points
327
Unplug the tv for 10 mins to let the tv reset then
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
Why do i have a green line on my tv
Vertical green lines on tv screen - Samsung 60" LED TV ... - iFixit
https://www.ifixit.com > Answers > View > Vertical+gre...
Jul 5, 2018 · 6 answers
Unplug all cables except the power cable, turn it on and see if you still have the green line. If without any image input, the line is there ...
How remove colored vertical lines all over screen of my LED ...
Dec 9, 2015
I have horizontal lines on part of my TV screen. - Sony Television
Dec 18, 2017
SOLVED: Why there's a green line - Samsung Television - iFixit
Aug 6, 2016
F-Series Vertical Green Line - Samsung Television - iFixit
Mar 8, 2018
More results from www.ifixit.com
Why does my TV have green lines on the screen? - Quora
https://www.quora.com > Why-does-my-TV-have-gree...
Sept 17, 2016 - With the green always on, it suggests that the cable the connects to the panel may have a bad line. Whether or not the cable has moved a bit to cause a short ...
6 answers · 10 votes: If its the same on every channel it means your TV is broke. I'm not tying to be a wise guy ...
There is a very thin green line going down my TV screen ...
Jan 3, 2021
How can I repair a TV with vertical lines on the ...
Dec 21, 2016
What causes a horizontal line on a flat screen TV? - Quora
Jul 25, 2018
What does it mean if a Samsung TV starts displaying ...
Jan 29, 2016
More results from www.quora.com
How to Get Rid of a Thin Green Line on an LCD - ItStillWorks
https://itstillworks.com > rid-thin-green-line-lcd-36231
A line of solid color indicates stuck pixels within your LCD. ... Your LCD produces specific colors and images by altering the colors of the thousands of tiny ...
5 tips to get rid of stripes on your TV screen - Coolblue
https://www.coolblue.be > advice > tips-for-removing-li...
Dec 18, 2021 - You can read 5 tips on removing horizontal or vertical lines on your TV screen here.
Vertical green line on Samsung LED TV : r/hometheater - Reddit
https://www.reddit.com > hometheater > comments > ve...
Apr 18, 2016 - It is most likely dead pixels within the monitor itself. You can try a stuck pixel video on YouTube that will flash colors or even give you a ...
1helpful
Samsung screen goes grey with green letter? Have Comcast cable
When the green letters appear, turn off the cable box only.
If the screen changes, the problem is in the cable box or hookup.
If the letters stay, there is a problem in your TV.
1helpful
2answers
Sony Playstation 3 + HDMI + Samsung Series 5 47"LCD Problems (tried all solutions i found) OK at my wits end now. Heres the testing I have done. Have the ps3 connected to the set using the av...
make sure ur not using both the av cable and the hdmi on some models it causes conflict although they are on different inputs. also did you try using a blu ray player or another ps3 on that hdmi port using the same cables or different cables? if another equipment work/don't work u can at least start to narrow down your problem..
3answers
I have the same problem with my Samsung LE46A656 A1F Full HD
If it was doing it on your old console then its the TV not the PS3.
Causes: HDMI cable (Replace cable), HDMI socket on TV (Get it repaired), If it happens on all HDMI inputs then the video board maybe faulty, Interference - location of PS3 to other equipment.
The first thing to do is move everything else away from your TV except for the PS3, now factory reset the Samsung TV and make sure your firmware is up to date my records show that an update came out in May for your TV, also factory reset the PS3 and setup the HDMI video settings using the wizrad in the PS3, now connect the PS3 through all HDMI inputs to see if its one input or all, if all inputs are the same then the TV maybe faulty.
Let me know how you get on.
Thanks
1helpful
PS3 can turn on, but T.V screen is black
turn power switch on in the back. red light on in the front, hold the power button until system turns back off. this resets all hardware settings. if this doesn't work and the system is ok (green light) then you have a connection problem to the tv
No blue color on tv screen
Your welcome ! please comment. Thank you !
PS3 consol on;y displays in green colour
had the same problem with vcr, i had the tv set to ntsc and the system here is used is PAL, look your tv set.
NO sound on HDMI3 port and when playing Blu-Ray DVD's the screen is pink
Go to the samsung website, and find out how to upgrade the firmware for your TV. You will probably need a portable usb memory stick to do so (if your TV is equipped with one). HDMI is an evolving technology, and firmware upgrades can resolve many of these quirky issues.
Here's a possibility from http://www.samsung.com/us/support/faqs/supportFaqList.do?group=&type=&subtype=&model_nm=LN-S4696D&dType=D&mType=UM&vType=R&prd_ia_cd=02010100&acc_ia_fl=&disp_nm=LN-S4696D
Which Samsung LCD TVs Have The HDMI 1.3 Interface? spacer.gif Of the LN-T series Samsung LCD TVs, those models whose last two digits are 61, 65, 66, 69, 71, or 81 (for example, LN-T4071F or LN-T466F) have the HDMI 1.3 interface.
Samsung LCD TVs with HDMI 1.3 interfaces also have HDMI-CEC (HDMI - Consumer Electronics Control). For information about CEC, click HERE.
For information about individual Samsung LCD TVs with HDMI 1.3 interfaces and HDMI-CEC, click HERE. When the Samsung LCD TV web page appears, select the TV model you want information about by clicking the drop down list under Product Finder on the left side of the page.
Though other series of Samsung LCD TVs (LN-R, LN-S, etc.) have HDMI connections, none have models with the HDMI 1.3 interface.
42"Samsung HCN4226WX/XAC
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
