My brother tried to read the memory card (a Lexar 1gb premium 60x) using a simm slot in his PC but was not able to. When I tried to use the card after replacing it in the camera I got the above message. Any ideas about what I can do to get the images back?
Martin
How do i play backcamcorder
The responses in bold are messages that are related to your problem see the one you think is best. Bill has a similar problem: http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00FPO2
Unsupported card perhaps?
POSSIBLE CAUSE: The optional memory card that is installed in the memory slot is not a supported memory card.
SOLUTION: Ensure that the memory card is the proper type for the camera.
Card is unformatted. Press OK to format card maybe?
POSSIBLE CAUSE: The optional memory card that is installed needs to be formatted.
SOLUTION: Format the memory card by using the Delete following option on the Playback menu or, if you do not want the card to be reformatted, remove the card from the camera.
Card has wrong format. Press OK to format card?
POSSIBLE CAUSE: The optional memory card that is installed is formatted for a different device, such as an MP3 player.
SOLUTION: Re-format the memory card by following the instructions on the Image Display (or remove the card from the camera if you do not want it to be re-formatted).
Unable to Format. Try Again?
POSSIBLE CAUSE: The optional memory card that is installed is corrupted.
SOLUTION: Replace the memory card, or if you have a memory card reader, try formatting the card on the computer. See the card reader documentation for instructions.
The card is locked. Please remove the card from your camera.
POSSIBLE CAUSE: When trying to configure the HP Instant Share menu, the optional memory card that is installed is locked.
SOLUTION: With the camera turned off, simply remove the memory card from the camera and continue the HP Instant Share task, or switch the locking tab on the card to the unlocked position before continuing.
Card locked.
POSSIBLE CAUSE: The optional memory card that is installed is locked.
SOLUTION: With the camera turned off, remove the memory card from the camera and switch the locking tab on the card to the unlocked position.
OR MAYBE Memory full or Card full,, Memory full or Card full. Camera cannot save Share selections,, Not applicable for the E-series digital cameras,, Memory/card too full to record audio,, Insufficient space on card to complete request.
Could be different voltages - some cards are 5V (older ones) and some are 3V or 3.3V. Wrong voltages can cause damage or corruption. The card may have become damaged or corrupted if supplied with 5V instead of the lower voltage. Not sure if you can recover it.
I have the EXACT same problem. Did you figure out how to retrieve the pics? I know mine were there in Colorado. But at -25, my camera "froze." I figured when it thawed that the card might not have an error but I was wrong! HELP! It also contained my sister's wedding pictures and the first time my 7 & 8 yr. olds saw snow!
I have the same problem with a transcend 1gb card
my camera is a Nikon coolpix L11 it says this card cannot be used
what should i do?
Exactly the same problem here. Got my camera in Dec 2007, got the Lexar SD, 1GB card, worked beautifully until yesterday. I tried to view a few pictures and got error. When I pressed playback button to view pics the screen goes black and then I recevied the message "this card connot be used". I have used this card and camera for hundreds of pics, transferred and deleted them fine until now. Help!!!!!
Try Formatting the Card.... I had a similar problem with one of my Cards and after a format it worked perfectly again..... Just make sure to do it in the CAMERA
