I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
