My Janome 10001 states that you can use USB cables to directly transfer a .jef embroidery file from computer to the sewing machine. I have tried everything--new cables, attempting to find drivers, etc. but just cannot make it transfer. No where does it say that you have to have any additional software to do this--such as the Janome customizing software. Does anyone know how to do the transfer by cables? Thanks, Nina
I too, have the same issue, with my janome 10001. I had to buy a memory card....download any designs to that...and insert in card reader in machine...
If anyone can explain the direct connection, with usb, I would love that.
I was having the exact same problem and just a minute ago was able to fix this. If you have the original installation cd for customizer 10000 plus when you first connect your usb cable from the machine to your xp machine choose the option to install the new hardware yourself. Then point to the cd rom drive and the drivers folder, win 2000 and the file inside of that will be the driver file. As soon as you install from this file it will be successful and you will be able to see all your Janome 10001 machine files on your computer when you work with customizer 10000 plus software. Let me know how it goes.
ec
You need to have Customizer og Digitizer pro to send design by cable to you MC10001.
You can also use a PCMCIA adapter in your MC10001 and a CF memorycard..you also need a memorycard reader to write to your CF card from your computer
Hi Nina.
Thher is may be virus on your computer. Update and do full scan you computer. There may be troyan or malware virus. If after it not be right, write me [email protected] email
Go to the Janome Web site and the Ask Jan Ask her about the Easy Transfer CD it is no longer available but she will send you a copy of it you may have to go to the Janome site after you get the cd and upgrade the Version 1 to 2 or 3 depending on the software version on your machine This is what I did because I go my machine from someone who lost the cd any questions contact me at [email protected]
Billie
SOURCE: Cannot get Janome 10001 to read via USB direct link from computer
here's how I do it.
1. Get the design into jef or sew format (the only kinds janome reads). You probably already knew this, but some newbies try to use pes or art files.
2. Save it onto your computer (and remember the name of the file). I have a folder in my computer labelled "embroidery files" and then have subfolders dividing up those designs - such as animals, flowers, fonts.
3. Hook your sewing machine up to the computer via the USB cable.
4. Pull up your Janome "Easy Transfer" program (it came as a CD with your machine - this is NOT the customizing software).
5. Use that program to find your embroidery file. It's not going to show sew and jef in the same file - you'll have to switch back and forth.
6. On your sewing machine, click on the bottom button (under the screen) that shows the computer to the sewing machine (the third one).
7. Now click on the computer software "write to machine" or whatever it's called (it will be on the top tool bar).
8. Your file will be written to the sewing machine's memory and organized by the embroidery hoop size (A, B, C).
9. It will stay in the sewing machine memory until you use the cable hookup to delete it (reverse of the writing).
10. The 10001 software ate lots of the resident memory in the sewing machine - you can't store as many designs in it as the 10000 would allow. That's perfectly ok, as it only takes a few moments to move designs in and out of the machine.
To be perfectly honest, I vastly prefer doing the USB cable transfer to using the memory card jammed into the card reader deal. It's easy and quick.
yes my xp does not have drivers for the 10000
