Sony DAV-DX375 System Logo
Posted on Oct 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IT DISPLAYS PROTECTOR PUSH POWER
MY SONY HCD-DX375 DISPLAYS "PROTECTOR PUSH POWER " WHAT DOES THAT MEAN
Anonymous
Level 3:
President:
  • Master 1,922 Answers
  • Posted on Oct 18, 2009
Anonymous
Master
Level 3:
President:
Answers
1922
Questions
Helped
617510
Points
4631
Its in standby, try it again, if it does it repeatedly theres a problem in the switching power supply not letting it power-up to save components
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3618
Points
My stereo displays PUSH POWER and will not work how do i resolve this problem is there anything i can do as it does this all the time
Protect push power sony HCD-VX55
I believe I already answered this.
Dav-dz30
Sounds like unit is in protect mode. This is usually caused by a problem in the amplifier section. Only way to fix is to replace the main board - hope it's under warranty, otherwise it's probably not worth fixing
1helpful
Sony product Home theater Model HCD-HDX265 , it is not turned on after standby it display PUSH POWER PROTECTOR
Needs repair either a output ic or a diode near one of the outputs most often takes care of it. Not a job for a diy-er.
When I turn on my Home Theater Sony Model hcd-hdx576wf this message appears, "protector, push power". what I can do?
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
1. Check the speaker wires and speakers for proper connections.
2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
1helpful
3answers
19helpful
5answers
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
