RTO PasLode 900420 Impulse Framing Nailer  Logo
Posted on Oct 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our nailer battery is fine and when you press the fire button the gun makes a faint thud as if trying to fire but no go. The gas is full. What should I look for
Anonymous
Level 3:
  • Master 2,176 Answers
  • Posted on Oct 18, 2009
Anonymous
Master
Level 3:
Answers
2176
Questions
6
Helped
1310676
Points
5445
Look for a jammed nail in the nose assembly, also what is the expiration date on the fuel (on the bottom). When was the last time cleaned and serviced, might be dirty and the cylinder dry. Let me know and I will try and help
Looking for the nearest repair shop for paslode nail gun in Northren Va
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
I have a paslode model IM250II 16 ga straight finish nailer that I bought used the gun fan and motor runs whin the trigger is pulled but it does not fire when the tip is pressed no pop no puff nothing I...
Fan running when trigger pressed is normal however to make it fire you need to press on the work probe first and the fan should start running, at this point the gas should be injected and pressing the trigger should create the spark to fire the gun, if all works as above but the gun won't fire check the gas, the metering valve on the can should have a yellow ring and when pressing the can nozzle on a hard surface, gas should be released, if not the can either has (a) insufficient gas, (b) the nozzle is not correctly fitted (c) the metering valve is faulty, if the can emits gas the gun will need to be checked for spark and the seals will need checking
My hitachi nail gun NR90gc2 will not fire
Check the date of the bottom of the gas. With the gas removed when you fire it you should hear a faint spark sound from the top. If gas is in date try putting it in your pocket for 10 minutes to warm it up. Open the front and make sure the piston is pushed all the way up into the machine.
Paslode IM350 90CT Nail Gun gun light green gas full battery charged fan works gun wont fire
Try a different gas cartridge and make sure the top of the cartridge is snapped tightly onto the cartridge body.
My hitachi nailer wont fire
Start with the basics:
First check that the butane (or whatever gas is used) canister is full. If empty, put in a new one.
Second check to make sure your battery is fully charged to be able to fire the spark to work the nail gun. If not get the battery charged and/or replaced as needed.
Third make sure all of the safeties are working properly and that you have them engaged to the piece of wood you are nailing when you try the trigger.
If beyond that it does not work it could be a bad trigger, a bad safety switch, or even a bad connection from the battery to the device.
4answers
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
3helpful
2answers
Nail gun
have you activated the fuel cell by pressing the black nozzle down onto the cylinder?
Hitachi NR 83A2S, Nail wont fire properly
The NR83a has an adjustment just below the triggering plunger. It is a 6mm hex head bolt with a locking nut. Loosen the nut and adjust screw out several turns and re-test. Make adjustment as necessary. I have seen many of these gun without the locking nut which allows the bolt the adjust itself all the way down. AS parts wear this screw needs to be adjusted. The pushing lever and the plunger are wearing smaller/shorter, that is unless the locking nut was missing. Remove gun from air supply for safety when making adjustments. Good Luck an email if you have other qustion about this gun.
1helpful
2answers
Hitachi Framing Gun Not Firing - Bad Battery?
Does the fan run and the light blink ont he nailer? I have one that I just bought. I put in the wrong type of nails and got one stuck. I had to take the front apart to clear it and now the damm thing wont fire. The green light blinks and the gas cartridge is basically full, even the fan does run after I release the push lever, but no fire???
I wonder if yours is the same as mine did fire for a couple nails first just fine then got jammed...
I will try to charge the battery more.... MAybe like yours it needs a strong charge for the spark...
Russ
Top RTO Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
