Question about American Standard 4275.550.002 ColonySoft Gooseneck Kitchen Faucet w/Two M
Hi Guys. My single spout kitchen faucet leaks when water turned on between bottom of faucet and the monting plate. Do I need to replace the cartrige, spout seal kit and the square seal ring or just one particular part. Thanks sooo much for any help. Jeff Oh by the way it is American Standard Model# 4453
  • 127 Answers
Spout seal kit , from what you described.
Posted on Oct 18, 2009
6ya staff
SOURCE:
How do l fix our leaky kitchen faucet
If its leaking from the base of the spout where its attached to the body, its most likely the O rings that need replacing. The spout body could also be leaking as the metal is quite thin and can develop pin holes under the bottom face of the spout. To determine it that's the problem, turn the water on, place your hand under the spout body, you should not get any water spray, if you do (its usually a fine mist so its hard to see, but you will feel it) the spout is bad, replace it.
Jul 27, 2014 | Belle Foret Kitchen Kitchen Faucet With...
7700 series Moen leaks at top and bottom of base hub
You can just replace the o-rings. You have to remove the large nut at the base of the spout. I posted a blog post -and a video about me replacing mine.
http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
The replacement o-ring and retainer parts were free to me. Hope it helps you.
Aug 17, 2011 | Moen Monticello Single-Handle Kitchen...
Moen 7700 leaking at base of faucet. how do you get to o-rings
Here's a link to show you how to get the spout off using "strap wrenches" The allow you to get the nut off at the base of the faucet spout without harming the chrome finish.
There is also a video at the bottom of the blog post showing how I did it.
Oct 17, 2010 | Moen Monticello Single-Handle Kitchen...
Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
Moen has a diverter built in that will need to be replaced.
use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
use a non silicone faucet lubricant when putting back together
Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
I have replaced the cartridge on my single faucet single handle moen kitchen tap, but water still leaks out under the central area that holds the cartridge. Is there a schematic that shows where and what...
did you replace the spout, -o- ring's. they would cause a leak to show up there as well.no need to pull cartridge again,just handle,and then pull up spout and that is it. there should be a small packet of lube w/ -o- ring kit,lube up around shaft and new -o- ring's.available at any good hrd ware store
Apr 19, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Moen kitchen faucet leak from spray
This might mean that the diverter in that controls the sprayer needs replacing. It is located behind the valve body underneath the tub spout sleeving
Feb 23, 2010 | Moen ShowHouse S711 Waterhill Single...
I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Aug 30, 2009 | Moen 87555C Trianna Single Handle Pulldown...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Kitchen faucet Remove
All faucets have a hot and cold line input. The single handle units have a mixing valve within the handle. Aside from removing the water lines there is usually some type of connecting bolts for the base plate as well that will need to be removed prior to removing the faucet. Do not forget to turn the shut off valves off at the wall before you remove the water lines.
Good Luck
Dec 03, 2008 | Plumbing
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
American Standard 4275.550.002 ColonySoft Gooseneck Kitchen Faucet w/Two M Logo
934 people viewed this question
Top American Standard Plumbing Experts
Thomas F. Schneider
Donni Steen
john h
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
