Whirlpool Front Loader Dryer Door will NOT stay closed
We just got our brand new Whirlpool Duet front loading dryer. The door will close and the dryer works, but it pops open. We have adjusted the legs. It is perfectly level.
Re: Whirlpool Front Loader Dryer Door will NOT stay...
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
If the door is popping open, that is causing the stoppage. There may be a way to adjust it, but I would have the people you bought it from fix it!! Best to have the device (spring/clip) that holds it closed replaced so it will give you longer life.
moch, the fact that the light is staying on when the door is closed leads me to believe that the door switch is the culprit. If that switch is not made you will not start. See if the pin is broken off. Start there and let me know. Catriver.
can oyu oppen the door nad physically push in on the door switch( little grey switch atop the door opening). do you hear it clicking on/off??? if not you have a bad door switch.
