Below are generic things to look for if getting a used bike.
Does the engine start easy and idle smoothly? Does it accelerate without hesitation?
Does the clutch engage and disengage smoothly?
Is the clutch lever easy to pull?
Any oil or coolant fluids leaking after a ride?
Do all gages work? Lights, horn and flashers?
Any red lights on the gages lit up? Any computer codes flashing?
Do front and back brakes operate and stop smoothly?
Is the motor oil pretty clean or really dirty? (Sign of how well the owner has cared for the bike).
Is the oil "white-ish"? (water in the oil. If motor is water cooled it's usually bad water pump seals).
Any funny sounds from the gear box? Anywhere else?
Does it shift smoothly up and down the full gear range? Neutral light come on properly?
Sprockets still have rounded tips not pointed? Well lubricated chain?
How much adjustment is left in the chain?
Good tires? How old is the battery? All lights work properly?
Is the upholstery good? Plastics cracked or broken?
Gas tank badly rusted inside? Do the wheels run true or weave?
Do the forks look bent from a side view or front view?
Testimonial: "Thaks for your input, very helpful! "
