When im using uTorrent i'll have 2 (or more) torrents downloading, but only 2 will ever be active (upload or download), i used to be able to have as many active torrents as i wanted, ps. wats the difference between ''start'' and ''force start''
You have to adjust your allowed downloads through your settings. I think the default with uTorrent is two at a time, all others will pend until the aforementioned ones have completed. You can also change your upload speed to suit the priorities of your download, I.E. You need something fast, slide the upload rate a little lower. Don't forget to slide your upload back up though, share!
To resolve your issue, please follow the instructions below.
Copy paste the link below in your browser to get the keygen and activation software:
http://www.alivetorrents.com/torrent/2615847/coreldraw-x4-+-keygen-re-uploaded-blaze69
You can download this by using a Torrent software, I use Utorrent. Download it in http://www.utorrent.com/.
When running the keygen and activation generator, make sure that you
are not connected to the internet and the anti-virus software is
disabled.
Disclaimer: Please be aware that there is no guarantee that this will work or that
it might cause damage to your system which is at your sole discretion
and as a contributor is not liable to such.
Guys..... Many of you would experience problems in using utorrent. Such as low downspeeds. Here is a solution for this problem. If you are not using browsers and you only download using torrent client right click on the torrent that is active and allocate high bandwidth to increase speed upto 20kbps above normal. Enjoy!!!!!!!! Also download using 1 or 2 torrents at a time. This will increase speed. And another thing disable your firewall while downloading. Your utorrent will go like a rocket!!!!!!
The
latest file sharing protocol bittorrent has modified everything when
it comes to file sharing. It is a nice platform for downloading large
files. Sharing of files include movies, iso images and MP3 songs.
Bittorent is mainly famous for illegal file sharing .
The Bittorrent system can be slow at times due to heavy traffic. so
let us tweak bittorrent sharing program a little bit.
There are a lot of different bittorrent clients that you can download.
I think the best are BitCommet and uTorrent.
Here is a few tips to speed up
uTorrent Client. Similar can be implemented on any other torrent
clients ,which you are using.
Step 1: Increase TCP connections
You need to increase the number of TCP
connections that are allowed at max.Windows XP Service Pack 2 came
with the number of allowed open connections to 10. This is to stop any
piece of spyware(in our case bittorent client even) from totally
taking over your internet connection. TCP connection allowed should be
50 for optimal performance. The best way to increase the maximum
number of connections is to apply patch that is available at www.lvllord.de. A nice way to fix
this is to download this patch .
The little tweak to the torrent client works
great in certain times. If you’re using uTorrent go to Options menu
then Preferences. In the Preferences go the Advanced Options. In the
advanced options change the net.max_halfopen connections to 80. In the
same section change the max half open tcp connections to 80. Once your
done click on OK and you are all set. This tweak will let the maximum
TCP connection available for the bittorrent client. Now start
downloading you’ll realize a little difference in the download speed.
Port forwarding technique is more effective than this.
A third point of interest is that some
“windows updates” revert your tweaked tcp connections back to 10. So
it’s wise to check this every now and then. You can check this by
going to (in windows xp) Start > Control Panel > Administrative Tools
> Event Viewer > System… Look for event 4226 (sort by event).
If there are a lot of daily occurrences it’s likely that the max amount
of half-open tcp connections was set back to 10. Or you’re infected
with some nasty spy ware…
Step 2:Torrent Client Configuration
In order to apply these tips you must know your maximum up- and
download speed. You can test your bandwidth over here (stop all
download activity while testing).
Settings 1-4 can be found in the options,
settings or preference tab of most torrent clients.
1. Maximum upload speed
Probably the most important setting there is.
Your connection is (sort of) like a pipeline, if you use you maximum
upload speed there’s not enough space left for the files you are
downloading. So you have to cap your upload speed.
Use the following formula to determine your
optimal upload speed…
80% of your maximum upload speed
so if your maximum upload speed is 40 kB/s,
the optimal upload rate is 32kB/s But keep seeding!
To resolve your issue, please follow the instructions below. Copy paste the link below in your browser to get the keygen and activation software: http://www.alivetorrents.com/torrent/2615847/coreldraw-x4-+-keygen-re-uploaded-blaze69
When
running the keygen and activation generator, make sure that you are
not connected to the internet and the anti-virus software is disabled.
When
When
Please comment if the information provided has been helpful for the
improvement of my support assistance. Thank you and regards.
you ll hav to download and install utorrent (application )..and then download xp from here(this is xp sp2) ,download d torrent and then use u torrent to download...
hope it helps ...
plz rate me if it helps so that i can help more people
The only way to make a torrent run any faster would be to increase your upload speed within the program. Torrents usually work on a speed ratio, meaning if your upload speed is set to 10 KB, your download may be capped at 200 KB.... if you up it to 20 KB upload then you'll max out at 400 KB down..
But, most of the time this isn't affecting anything, especially in utorrent. The most likely scenario is that the people you are getting it from have very slow connections or have many people getting the file at once. That's the downsides of torrents, it can take days or even weeks to download some files.
