I just hooked up a Samsung Blue Ray player to my LG 42LG50 42 in. TV, when the camera moves the screen twitches. It does not do this with regular DVD's. I did cheap out on the HDMI cable, could this be the problem?
What happens when you take the bluray hdmi out? or turn the bluray power off from wall? can you connect audio from bluray with a separate cable? often one device overrides the other. there may be a way of daisy chaining the devices
First you have to hook up network cable to Blue Ray player and to router
Next update software in Blue Ray player by going thru your menu in blue ray player to settings
If you have your blue ray player with Netflix app then all
you do is click on app and log in.
And make sure HDMI cable is plugged into TV.
And that should work for you. Any problems write me back.
Pickled! You did right by checking the cables, the tv inputs and as well the output on the blue ray...even by replacing the blue ray. Which leads to a problem within the tv monitor. I can only guess there is something in the software of the tv that is causing the problem. I can only suggest two options. If can connect the tv to a network via CAT5 cable, you can do a frimware update to the tv. Sort of like a software update. If it is not available, try to swap the HDMI cable for the 5 RCA component video. It will still carry HD signal, just not as crisp as the HDMI. I would be floored if the same thing happened with the component cable.
Sorry, man I have the same problem, with the same tv and player. Did you ever get a solution? LG Service Tech came out and his LG bluray player worked, whereas my Samsung didn't hooked to the TV. (It would spordically work going thru my HK254 AVR.)
He said either 1) the Samsung player was defaulting to a format that the Zenith being 3 years old could not decode (eg. 1080P) or that I might need to change inputs several times to get it to sync up or 3) by an LG Bluray player.
He said the Zenith was old and that newer sets are built with circuitry to help navigate the handshake easier. He couldn't find any service bulletins on it, and the one I got from LG he said didn't exist.
The TV remote may have a button stating Aspect Ratio, or similar. Usually when you keep hitting it, it may cycle through available settings like 16:9, 4:3, Wide, Zoom, etc. If not, or if the remote doesn't have this button, check the TV's onscreen display but usually the source device like the DVD player is in control of how the image fits the screen so the DVD player's onscreen display or it's remote may also have the Aspect option so check it as well. Todays TV's are alot like PC monitors and they "talk" to the device in control of the signal. Your Samsung may have worked better with the Blu Ray, or maybe it's the other way around but your new LG may not have an automatic adjustment like the Samsung may have had.
