Televison & Video Logo
Posted on Dec 28, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trouble shooting where can i buy the plyback of konka model k2136h? and the vertical transistor #1555 tnx you waiting for your reply.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 375 Answers
  • Posted on Mar 28, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
375
Questions
0
Helped
88433
Points
559
Konka crt tv model k1998 have only horizontal line on screen .
Check and replace the damaged component/s at its vertical scan output section circuit. The vertical scan is absent now. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Troubleshooting to similar faults are given.
The circuit diagram to this set too might be there. Type in the IC number [chroma jungle] in the search box, at the top right of the display window, to get gathered the posts that have circuit diagram.
2answers
When turned on you view only a vertical line. i beleave a power surge caused this. what part or parts do i need to replace. mod no-ps35123. tnank you
There is no vertical chip in this model/ ctc 169.
it's a transistor- resistor - cap circuit.
It's either the yoke wires on neck of the tube have
become de-soldered or the more likely possibility
is the viliot / white wire from the yoke have simply
become de-soldered if you first re-solder those two
Tv trouble shooting.
maybe deagos lost at the back of your transistor, horizontal ic check.
2answers
Came home car running fine next morning no start
try changing the ignition module ,not sure on this model but i think its inside the dist
Troubleshooting t.v
yours tv ,problem on the ply back i think shortcircuits you must changing the plyback a new one from A Halim Yogyakarta Indonesia
Picture disappears
My Konka LCD model KDL32AT23U Displayed a picture, then vanished, showing different colored vertical lines in horizontal blue bands.Then I could not turn it off with the remote or standby button on the side.Only with the main switch.What's wrong??
This is the same problem posted by kukish on july 26,2008
For trouble shooting
circuitos de fuente sin numero
Re: Panasonic CTV TC-20V50P
Hi, Possibly an open resistor in the 100 Mega Ohms range (On some models as high as 470M). Either in series or parallel to ground of the G1, G2 or Screen supply. This would normally be in the PCB at the rear/neck of the picture tube. Of course, it is also possible that the Screen adjustment or the FBT itself is already faulty. Hope this be of some help. Good luck and kind regards.
1helpful
Picture has a horizontal row
this symptom is caused by a trouble in the integrated circuit of in the vertical oscillator circuit. try to look if your tv has a vertical hold control at the back or inside, if it does not have, u have a problem in the vertical oscillator circuit. by the way, its not the horizontal that u should concentrate into, its the vertical. coz this is a vertical sync problem.
Top Konka Televison & Video Experts
ZJ Limited
ZJ Limited
Paul Bade
matt martin
matt martin
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
