Dear Sir/Mme!
2x2GB identical memory cards are inserted (into the yellow banks of the Asus M2V), but the bios sees only 3,2 GB of it. What is the problem?
With best regards
Endre from Hungary.
I think you may be usinf DDR DUAL channel memory under XP
If this is the case it is normal on a lot of machines.
XP has a memory limit and you have reached it.
If it is dual channel you will still have a noticable difference in overall speed.
No problem. This is how a Windows 32 bit o/s allocates RAM. To see it all you'd need a 64 bit o/s. Hope this helps.
Is the memory has the same speed... if not!!!,,, u can't longer have a 4gb memory... try to look for it..
