Same problem I'm having--when I turn it on the screen is blank and if you shoot a photo the flash works but the photo blank. It started out with the screen being partially blocked at the top--now it's the whole screen. I'm thinking I've done something simple like switched a control on/off but I can't figure it out. I can view images of photos taken before this problem. Hoping it's simple...Same problem I'm having--when I turn it on the screen is blank and if you shoot a photo the flash works but the photo blank. It started out with the screen being partially blocked at the top--now it's the whole screen. I'm thinking I've done something simple like switched a control on/off but I can't figure it out. I can view images of photos taken before this problem. Hoping it's simple...
You can't post conmments that contain an email address.
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do:
You need to have a TV with Video in and Video out jacks.
Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
This may sound like a dumb question, but are you sure that you had the camera set to the video recording mode? Several of the Canon digital PowerShots will show the movie icon on the LCD screen even when the camera is in image record mode. Why, I don't know. Ensure that you set the camera into movie mode by pressing your Func/Set button to go into the Function Menu and then selecting the movie mode that you want to shoot in. Press the Func/Set button again to get out of the Function Menu and you will not only see a movie camera icon on the LCD screen, but also a set of numbers in the bottom left hand corner representing the recording resolution (e.g. 640 pixels) and the frames per second (e.g. 30).
And just in case you did have the camera set in movie mode, make sure that you don't do what many people have inadvertantly done and mistake the video clip for a .jpg image in the playback screen. Videos will of course have the movie camera icon in the upper corner of the image and are viewed by pressing the Set button twice to begin the playback.
If both of these steps were performed properly then your camera may have a hardware issue. As a last resort, try performing a reset from within the menu just to be on the safe side and see if it makes a difference. If not you may need service. Hope this helps.
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Knowledge Article
C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
Follow
this procedure to troubleshoot if there is no picture or a black screen
NOTES:
Because
each of these steps represents a possible solution to this issue, check
the viewfinder or LCD status after completing each step.
It
may be necessary to refer to the operating instructions provided with
the camcorder for information on how to perform a task on your specific
model.
Ensure the lens cap on the front of the camcorder has been removed.
Ensure a fully-charged battery is inserted in the camcorder.
Ensure the STANDBY/LOCK switch is set to the STANDBY position.
Turn on the camcorder and set it to the CAMERA mode.
Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT:
Some camcorders have both a viewfinder and LCD. To conserve power, the
viewfinder and LCD will not display at the same time. To use the
viewfinder, the LCD must be closed.
If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick.
I guess I'm not sure what you need.
