Cars & Trucks Logo
Posted on Oct 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the capacity of the transfer case and exactly what fluid do i use
ZJ Limited
Level 3:
  • Chevrolet Master 17,989 Answers
  • Posted on Oct 16, 2009
ZJ Limited
Chevrolet Master
Level 3:
Answers
17989
Questions
0
Helped
14455712
Points
60858
GM Full-Size Trucks 1980-1987 Repair Guide
Transfer Case - FLUID RECOMMENDATIONS
The type of lubricant used in the transfer case varies with model year and type of transfer case. Refer to the list below for the type that applies to your truck.
1980
Conventional transfer cases require SAE 80W or SAE 80W-90 GL-5 gear lubricant.
Full time systems use SAE 10W-30 or 10W-40 engine oil.
1981
Conventional transfer cases require DEXRON®II transmission fluid.
1982-85
All transfer cases require DEXRON®II transmission fluid.
1986-87
All transfer cases except the K30/35 series require DEXRON®II transmission fluid.
For fluid recommendations for the K30/35 transfer cases refer to the owner's manual.
LEVEL CHECKS
Fig. Model 208 Transfer Case
Check the four wheel drive transfer case lubricant level every 4 months or 6,000 miles.
  1. With the truck parked on a level surface and the parking brake firmly applied, remove the filler plug from the rear of the transfer case (behind the transmission). Be careful not to take out the drain plug at the bottom.
  2. If lubricant trickles out, there is enough. If not, carefully insert a finger and check that the level is up to the edge of the hole, EXCEPT in full time four wheel drive cases should be 1 /2 in. below the hole.
Lubricant may be added, if necessary, with a funnel and tube, or a squeeze bulb.
DRAIN AND REFILL
Part Time Systems
No intervals are specified for changing transfer case lubricant, but it is a good idea for trucks that are worked hard or driven in deep water.
  1. With the transfer case warmed up, park on a level surface and apply the parking brake.
  2. Slide a pan of a least 6 pts. capacity under the case drain plug.
  3. Remove the filler plug from the rear of the transfer case (behind the transmission). Remove the drain plug from the bottom.
  4. Wipe the area clean and replace the drain plug.
  5. Add lubricant with a suction gun or squeeze bulb. Conventional transfer cases require SAE 80W-90 GL-5 Gear Lubricant.
  6. When the lubricant level is up to the bottom of the filler hole, replace the plug.
Full Time Four Wheel Drive
The full time system requires oil changes at regular intervals, according to the amount and type of work done by the unit. Trucks used for normal on-off road work should have the transfer case oil changed at 24,000 mile intervals. When used for heavy duty work, trailer towing, snowplowing, and the like, the interval should be halved to 12,000 miles. If the truck is exposed to extremely dusty or muddy conditions, the oil should be changed at 1,000 mile intervals.
The transfer case oil must be hot before changing. Drive the truck until the engine has reached normal operating temperature, and park on a level surface.
  1. Slide a pan of at least 8 pts. capacity under the case drain plug.
  2. Remove the filler plug.
  3. Remove the lowest bolt from the front output shaft rear bearing retainer cover, and allow the lubricant to drain. Be careful; the oil will be hot. There may be a drain plug. If so, remove that instead.
  4. Remove the six bolts on the left (driver's) side of the case which secure to P.T.O. (power take-off) cover. Remove this cover and allow the lubricant to drain out.
  5. Remove the speedometer driven gear from the upper left rear corner of the case.
  6. Use a suction gun to remove as much lubricant as possible from the case cover location and the speedometer gear location.
  7. Install the speedometer driven gear, the P.T.O. cover, and the lowest bolt or drain plug.
  8. Add approximately seven pints of oil through the filler plug opening. The proper oil to use is 10W-30 or 10W-40 engine oil.
  9. Check the fluid level and add sufficient oil to raise the level to 1 /2 in. below the filler plug opening. Replace the plug, and wipe the surfaces of the case and skid plate to remove any excess oil. Drive the truck and check for leaks.
I really hope help ypou woth this (remember rated this help) Good luck.
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Nov 08, 2008
SOURCE: transfer case fluid?
Under the truck at the rear of the transfer case there is a plug, pull it out, you should be able to touch the fluid with your little finger, that will be a level that is just below the fill hole
Anonymous
  • 3 Answers
  • Posted on Sep 24, 2009
SOURCE: fluid in a transfer case
no do not put atf in the transfer case chevy has a product for this it is found in the owners manual or jo in to gm and ask for fluid for a 03 chevy 2500 transfer case
fmdsaab
  • 157 Answers
  • Posted on Nov 22, 2009
SOURCE: is the tranny and transfer case fluid shared? are
seperate fluid
Anonymous
  • 6982 Answers
SOURCE: need to know fluid capacity of differential
Dont remember specific amounts for those but they are "fill till it comes out of fill hole" On flat level ground. About three gallons should do it with some leftover. Check with your parts house or dealer to make sure of what goes into the transfer case...many now use dextron III not gear lube.
Any excessive metal flakes in old lube indicates a problem with internal parts wear for either diffs or case. (everything wears so there is always some, it just shouldn't look like glitter paint)
There should be tow approx 1" nuts on the back of the case lower one is drain, upper to fill. Diff cover needs to be removed to drain. Fill through plug on cover.
Testimonial: "Thanks for the information. This will save me a lot of money. Thanks again!"
Anonymous
  • Posted on Jan 04, 2010
SOURCE: type and capacity of fluids
The kind of fluid needed is called GLS this is not something you can get at some grease and go. To my knowledge this particular fluid is still a dealer only item. DO NOT put ATF in your transfer case. I don't remember the capacity but the dealership would have this information.
Fluid capacity and type for 2004 trail blazer transfer case
The only recommended fluid for the transfer case is GM AutoTrak and 2 one liter bottles are used. Also, it is very important to change this fluid every 50K miles.
1helpful
TYPE OF TRANSFER CASE FLUID TO PUT IN MY 95 JEEP CHEROKEE 5.2
The transfer case in the 95's use Dexron Automatic transmission fluid. The fill capacity is 1.2 liters.
What is the oil capacity for a front & rear axle for a Jeep Grand Cherokee 3.0
FRONT AXLE ± 0.3 L (2 oz.)
C200F
1.7L (57.5 Ounces)
C200FE
1.7L (57.5 Ounces)***
REAR AXLE ± 0.3 L (2 oz.)
C213R
2.07L (70 Ounces)
C213RE
2.24L (75.5 Ounces)***
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
** Includes 0.9L (1.0 Quarts) for coolant reservoir.
***ELSD - add 118 ml (4 Ounces) of friction modifier.
Transfer Case (3.7L Engine)
Mopar® ATF+4 Automatic Transmission Fluid
Transfer Case (3.0/4.7/5.7L Engines)
Mopar® NV 247/245 Transfer Case Lubricant
Transfer Case (6.1L Engine)
Mopar® NV146 Transfer Case Fluid. Usage of other fluid/lubricants is NOT recommended.
Axle Differential (Front-Rear)
Mopar® Synthetic Gear & Axle Lubricant SAE 75W-140 (API-GL5) or equivalent with friction modifier additive.
4helpful
3answers
What kind of oil goes in the transfer case for the four wheel drive
If it's a manual case ( pull stick ) then it's dexron III automatic trans fluid , if it's automatic ( push button ) then use GM part # 12378396
7helpful
2answers
Fluid capacities and fluid specs
2000 TOYOTA TACOMA 2.7L 4-cyl Engine Code 3RZ-FE
Engine Oil Grade 1......API* All TEMPS......5W-30 Optional ..10W-30
Engine, 2WD, with filter..........5.5 liters
Engine, 4WD, with filter..........5.4 liters
Manual Transmission,......GL-5/ GL-4 All TEMPS......75W-90
Automatic Transmission,A340E......AF3 / A43D......AF3
Differential, Front/ Rear W/ ADRD......GL-5 ALL TEMPS......75W-90
Differential, Front Less ADRD......GL-5 ALL TEMPS......80W-90
Transfer Case,......GL-4/GL-5 ALL TEMPS......75W-90 Gear oil.
Capacity:
Cooling System, Initial Fill..........8.5 liters
Automatic Transmission, A340E Initial Fill..........1.6 liters
Automatic Transmission, A340F Initial Fill..........2 liters
Automatic Transmission, A43D Initial Fill..........2.4 liters
Automatic Transmission, Total Fill
4 speed A340E..........7.2 liters
4 speed A340F..........10.1 liters
4 speed A43D..........6.5 liters
Manual Transmission, ..........2.5 liters
Differential, With ADRD Front..........1.2 liters
Differential, Without ADRD Front..........1.1 liters
Differential, 2WD V6 Rear..........2.6 liters
Differential, 4WD Extra Long Rear..........2.5 liters
Differential, Short WB With LSD Rear..........2.7 liters
Differential, Short WB Without LS Rear..........2.6 liters
Transfer Case, Electronic..........1.2 liters
Transfer Case, STD..........1 liters
2helpful
Type and capacity of fluids
2answers
What kinda oil do you use for the transfer case
it is from gm a blue oil called automatic transfer case oin
8helpful
2answers
What;s the oil capacity for a 2002 chevy trailblazer 4.2 6 cyl?
Here are the Fluid CAPACITIES & MORE:
Engine, with filter..........4.6 quarts[1]
Cooling System, Initial Fill..........12.0 quarts
4 speed 4L60, 60E..........11.0 quarts
Manual Transmission, NV1500..........5.7 pints
Manual Transmission, NV3500..........4.2 pints
Differential, with 8.6 ring gear Rear..........4.0 pints
Differential, with 7.25 ring gear Front..........2.5 pints[2]
Differential, with 8.25 ring gear Front..........4.2 pints[2]
Differential, with 9.25 ring gear Front..........5.9 pints[2]
Differential, Front..........2.5 pints
Differential, Rear..........4.0 pints
Transfer Case,BW4472..........2.5 pints
Transfer Case,NV136/236/246..........4.0 pints
Transfer Case,NP207..........4.6 pints
Transfer Case,NP231, NP233..........2.3 pints[3]
Transfer Case,NV231/233..........2.1 pints[3]
1. After refill check oil level.
2. Do not use synthetic lubricant in axles using RTV sealant.
Synthetic lubricant will chemically atack RTV sealant.
3. Identification: check tag on case.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
