Sharp UX 300 Plain Paper Thermal transfer Fax Logo
Posted on Dec 28, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone can not get adail tone on phone, checked line, every things ok the words on telephone screen says ''on hook dail''
john archer
Level 2:
  • Expert 186 Answers
  • Posted on Jan 03, 2008
john archer
Expert
Level 2:
Answers
186
Questions
Helped
129952
Points
276
Make sure the phone cord from the wall is plugged into the outlet on the machine marked LINE and not PHONE.
ERROR T82 BIZHUBC280 IMPOSSIBLE TO SEND OR RECEIVE FAX
Check your fax line connection is the FAX line plugged into the Line jack on the copier and NOT THE TELE connector. Must be Line. Take a old phone like a old princess phone and hook it up to the wall get a good dial tone call some one any noise? Have some one call the fax number OK if hooked to the copier get the tradition noise of a fax line, Check the fax line itself use only one with two wires not four, black and yellow only no red and green. Also put on one of the EMI devices on the cable going into the copier cut down on electrical noise. Line can not be digital must be all analog (POT) Plain Old Telephone, have your phone provider check the line.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2helpful
2answers
Can not get a dial tone. Phone appears to be off the hook. How do I trouble shoot it?
Unplug the phone line from the fax machine. Wait at least 1 minute then call the phone number that goes to the fax machine from another line such as a cell phone. Make sure you get a ring and not a busy signal. If you get a ring then hang up the phone. Plug in the fax machine again and call the fax number again. If you get a busy signal then either your phone if off the hook, the switch that is actuated when the phone is placed in the cradle is bad or your modem in the fax machine itself has gone bad. Another thing to try is unplug the fax machines power cord for 30 seconds then plug it back in. I have seen the modems get "locked up" and keep the phone line open. Unplugging will sometimes reset this and get it working again.
Good Luck and Thank You for using Fixya.
1helpful
2answers
Our company has a Panasonic kx-t7731 main line has no dail tone.
On that phone, press PROGRAM the button and dial 01 STORE.
Press program again to exit programming.
It's not likely you'll be needing the Group Log In/Out button.
Carl
No dail tone
IS THE PHONE LINE PLUGGED IN TO THE RIGHJT JACK YOU WILL NEED TO CHECK THIS OUT FIRST GOOD LUCK BROTHER TECH
2 beeps, no dial tone
hand set no dail tone cant all out on the hand set due to no dail tone
2answers
No dail tone
Check the cor and cos setting of the phone It shold have the permissions to call outside
2helpful
8answers
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
2answers
Modem dialtone problems
Is the phone line going to the modem live?
2answers
TC1200 TONES/PULSES
There is usually a switch to change it from dial pulse to touch tone.If there is no switch check your user manual to see if there is a screen option.
tk46
3answers
Phone
WHat model is the fax machine? Also check to make sure that the phone line and the fax line are not 2 different phone jacks. Also if the phoneline and fax line are on the same jack, make sure to program the fax number into the fax machine. Also, double check if the fax machine has an in and out phone jack that it is in the in jack.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
