Mitsubishi VS-60705 60" Rear Projection Television Logo
Posted on Oct 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am experiencing a problem with my Mitsubishi VS-60705, I did the error code check by holding menu and input and the error code was 12, what does that mean and what can I do, how expensive to fix?
Anonymous
Level 2:
  • Expert 60 Answers
  • Posted on Oct 17, 2009
Anonymous
Expert
Level 2:
Answers
60
Questions
8
Helped
24143
Points
124
Sorry,
Error code 12 means nothing is wrong, so the error code is of no help when obviously something is wrong.
My Mitsubishi TV power light comes for about 12 seconds, without any picture, and turns off.
Try the self check when power light goes off, on front press and hold both the menu and input buttons for at least 5 seconds and let both go.
Power light will blink a two digit error code like 2 blinks,2blinks, pause and repeat it several times.
What error code do you find?
SD TECH
1helpful
Need codes to program universal remote for model # vs-60705
0150, 0019, 0093, 0178 Try out these codes
if your remote only takes 3 digit codes then remove the leading 0 from the codes.
3helpful
AFTER TURNING ON TV ,THE GREEN LIGHT COMES ,SOUND STARTS AND THEN TV TURNS OFF ASAP
after tv shuts off press and hold menu and input buttons on tv at same time for about 8 second. power led will start to blink error code 12 ok 22 dead short 23 deflection failore 24 vertical failore. after you know error code have electronic technition repair for you. J.D.W.
5helpful
Mitsubishi vs-60705 grenn power button goes on
It is an error code for short protection---the most common cause for this is one or both of the pico fuses that protect the convergence IC's are bad--set will detect no voltage and instantly shut off.
I do this here for free so if this has been helpful give me a vote here. if you have questions or need help:
[email protected]
Mitsubishi VS-60705, Turns on/Turns off.
Unfortunately you will need an experienced TV tech.
This unit will need 2 ICs STK392-110 for 1 has shorted and caused damage to the 2nd as a result blowing 1 or 2 pico fuses in the power supply.
It is an involved job and may be somewhat costly depending on the pricing in your area.
Hope this helps Normal 0 false false false MicrosoftInternetExplorer4
1helpful
Vs-50607 turns off by itself it might come on after about 8hrs
if you hold menu and input on the front panel it will blink a code to tell you
where the error likely is. hold the buttons for 5 seconds and you'll get a 2
digit error, like 1 2 = no error..
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
let me know what you find.. it will determine area of failure
TV won't turn on
try pressing in both the menu and the input/device buttons together on the front of the set and hold for five seconds to see if the led blinks a two digit code. Then let me know the blink code.
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
4helpful
2answers
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
5helpful
2answers
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
