Can't exactly tell what you need. See if you can find it on this page and maybe that will give you an answer. https://www.searspartsdirect.com/model-number/mdbtt50aws/3048/0130000.html?sid=ps:GOOGLE:LKA_PM_Maytag_Exact:Dishwashers:mdbtt50aws&k_clickID=bc276823-c73d-402e-8108-8dca92f89665&kenibpid=p.590.bc276823-c73d-402e-8108-8dca92f89665.2138080&gclid=CjwKCAiAnabTBRA6EiwAemvBd0XpSS1QJj45nAOioA9dr98p2RxwyLGxojMnw4fEXHbDYQdSsqCFQRoCxr4QAvD_BwE
SOURCE: Maytag Dishwasher Latch Sticks
John, I had the same problem and just disassembled by removing the dozen or so screws around the inside of the door, lifting the waterproof panel, and pulling up the latch assembly to see what was broken. In my case there were plastic pieces broken off of the latch handle and where the latch hinges on the back of the control panel-the latter piece is $50 to replace. unfortunately. Good news is the disassembly and replacement will be easy as a DYI. Sorry this is too late to help you, but maybe others will have the same problem. Bruce
SOURCE: soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
SOURCE: Problem with dishwasher detergent dispenser
we should replace the whole dispenser otherwise it can be leaked
SOURCE: Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
