Dell BIOS Beep Codes: Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
11 Beeps - Bad Cache Memory - test failed (replace cache memory)
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
1-1-4-1 - Cache Error (level 2)
1-2-2-3 - BIOS ROM Checksum
1-3-1-1 - DRAM Refresh Test
1-3-1-3 - Keyboard controller test
1-3-4-1 - RAM Failure on address line xxxx (check memory)
1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
I'm not sure with your beep code.. but here is the list of known beep codes for dell motherboards
Beep codes Possible Causes Solution 1-2 no video card detected Reseat the video card 1-2-2-3 BIOS ROM checksum error 1-3-1-1 DRAM refresh error Reseat the memory card 1-3-1-3 Keyboard error Keyboard connector 1-3-3-1 memory card Reseat the memory card 1-3-4-1 RAM failure on line xxx Reseat the memory card 1-3-4-3 RAM failure on data bits Reseat the memory card 1-4-1-1 RAM failure on data bits Reseat the memory card
Please try a different card & confirm that your phone card reader are working or not. If its working then you sure that, you r memory card have problem. So try to format it and then use. Some time virus's block the card.
If you seen that, your phone does not read any card then visit the nokia service center and give them for service/ internal dust cleaning.
Thanks.
1 Long Beep: Memory problem Explanation: There is a failure of some sort related to the system memory. Diagnosis: The first bank of memory probably has a failure of some sort; this is
usually just a physical problem such as an incorrectly inserted module, but may also mean
a bad memory chip in a module. It is possible that there is a failure related to the
motherboard or a system device as well.
Here are the beep codes for Dell. Count the beeps sequences and compare them to the list. Dell BIOS Beep Codes:
Beep Codes
Possible Causes
Corrective Action
1 - 2
1 - 2 - 2 - 3
1 - 3 - 1 - 1
DRAM refresh error
1 - 3 - 1 - 3
1 - 3 - 3 - 1
1 - 3 - 4 - 1
1 - 3 - 4 - 3
1 - 4 - 1 - 1
Beep Codes
Possible Causes
Corrective Action
1 - 2
1 - 2 - 2 - 3
1 - 3 - 1 - 1
DRAM refresh error
1 - 3 - 1 - 3
1 - 3 - 3 - 1
1 - 3 - 4 - 1
1 - 3 - 4 - 3
1 - 4 - 1 - 1
More info here: http://www.bioscentral.com/postcodes/dellbios.htm
Typically, a system that won't pass POST (Power On Self Test) will beep in a pattern indicating what the problem is. Here's the beep codes for Dell systems:
Beep Codes
Possible Causes
Corrective Action
1 - 2
1 - 2 - 2 - 3
1 - 3 - 1 - 1
DRAM refresh error
1 - 3 - 1 - 3
1 - 3 - 3 - 1
1 - 3 - 4 - 1
1 - 3 - 4 - 3
1 - 4 - 1 - 1
