1)Insert the software and drivers disk into your CD/DVD drive. If an auto play window pops open, select the "Install" option. This will begin the installation wizard automatically. If the auto play option doesn't start, go on to Step 2.
2) Double-click on the computer icon on your desktop or navigate to "My Computer" by opening up the Start menu and selecting "My Computer." A window will pop open. Right-click on the drive were the disc is located, for example DVD Drive (F:). Select the "Install" option to start the installation wizard.
3)Plug your webcam into the desired USB port. If you have not installed the drivers, the device driver wizard will begin searching for the drivers on its own. Windows XP, Vista and Windows 7 utilize the plug-and-play option and will automatically find the drivers for you. However, it is recommended to install the drivers from the disc or from the Creative Labs website.
Hi.
Here is what I found on the network regarding your problem.
It might help you.
Here's the scenario: you download the latest and greatest version of the Adobe Flash Player. After it finishes installing, you go to a site featuring Flash content and are greeted with a message notifying you that you need to install Flash Player, but didn't you just do that? To properly update your Flash Player, you need to run the installation as Administrator. Follow these steps to properly install Adobe Flash Player:
For Vista (32 bit):
1. Open Computer.
2. Navigate to C:\Windows\System32\.
3. Scroll down and open the Macromed directory.
4. Open the Flash directory.
5. Right-click FlashUtil9b.
6. Select Run as Administrator.
7. When the UAC prompt appears, select Continue.
8. Follow the Flash Player installation wizard. For Vista (64 bit):
1. Open Computer.
2. Navigate to C:\Windows\SysWOW64\.
Once the wizard completes, Flash Player has been properly installed and will now function properly.
Download the latest and greatest version of the Adobe Flash Player. After it finishes installing, you go to a site featuring Flash content and are greeted with a message notifying you that you need to install Flash Player, but didn't you just do that? To properly update your Flash Player, you need to run the installation as Administrator. Follow these steps to properly install Adobe Flash Player:
For Vista (32 bit):
1. Open Computer.
For Vista (64 bit):
1. Open Computer.
Thank you for using FixYa Don't forget to vote thanks!!
this may not supprt ur system hardware..then u hv to insert the driver n utilty disk given by ur notebook company ...then install the realtek 4 ur hardware...........hop it help u
You cannot install Windows XP over WIndows Vista. Microsoft has put a lock on the Vista software and will not allow you to downgrade to a lower software. The only way you can do it is to wipe your hard drive completely clean first with a disk deleting software or with the command "fdisk" at the DOS prompt. However, this is dangerous and I do not recommend it unless you have someone professionally trained to do it. It will wipe everything off of your disk and then you can load Windows XP.
Don't forget to rate his solution with 4 stars before you log out.
