If the disc inside has jammed or there is any damage to the mech for opening this can cause the jam you can open it manually by getting a paper clip ot long needle and look to the front panel just below the draw htere is a small hole insert the paperclip end into this and push the the pin in it should go a way in this will actuat a release lever the tray shoul open for you you can check the inside mech after this it may need some grease on the draw runner. Good Luck A
