Press cursor-right (marked with a lightning bolt) to bring up the flash menu, then select the lightning-bolt-in-a-circle-with-a-slash-through-it icon.
SOURCE: Canon power shot SD 750
The lens needs to be dissasembled and repaired or even replaced. A good camera repair tech can do this for around $100.
SOURCE: need new mannual
You can download user manuals for the Canon Powershot SD750 from Canon's website at this link.
SOURCE: Cannon SD 750 - when i try to take a picture a black screen appe
Think that you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
SOURCE: how do i turn off the flash on cannon power shot
The little lightning bolt on the right side of the function switch (3:00) gets you to the options. If you keep pushing it you will get the different settings. In the manual on Page 68 the different settings are given for the different icons.
For the manual Click Here.
Thanks for using Fixya. Happy New Year.
SOURCE: Canon Power shot sd 1000
what u have to do is when u are going to take the picture click on the little lightening bolt next to the func. set button. 2 pictures will pop up- one of a lightening bolt and another with a lightening bolt with a slash through it. hit the lightening bolt button again and it will select the slashed lightening bolt picture. this will turn flash off to turn it back on go back to the screen with the 2 bolts the same way but press the button with the flower to the right of the func. set button.
