set the pc screen resolution to a low setting.
connect the vga output on the pc to an external monitor and check that the video appears on the external monitor. change the mode of operation on the pc until it does appear.
then disconnect the external monitor at the end of the vga cable, and connect the free cable end to the projector and auto source search for the vga input signal
You can try removing the main board & reseating it. Also try plugging into another outlet & make sure the plug has a ground prong on it. Itshould have 2 flat & 1 pin shaped prongs. Otherwise the clicking sound may be the lamp trying to ignite. Normally when you plug in the LP530 the green power light is on steady & then you press it to start the lamp. If its flashing as soon as you plug it in it's likely that the main board is bad, the button board is bad, or the ballast/power board is bad.
You should remove the lamp & inspect it. It should be clear without bulging in the little bulb behind the lamp glass. I service LP530s all the time & something like that is usually the main board.
Good luck,
Jim
The ambient temperature in the room is to high. Try lowering the room temperature. If that doesn't work get a small fan and place it near the projector ro provide extra cooling. The projector is running border line on high temperature and just needs a little extra cooling.
start the connecting all over again, by following the steps below:
1. Turn your computer off.
2. Connect the cable from the computer to the projector. If you want to
have your monitor to be hooked up as well, connect a splitter to the
video out port (DVI or VGA). You can also just hook the projector up to
the second port on your video card (If you have one) or if you have a
laptop, you can connect to the video out port on the back.
3. Turn the computer on and boot into your desktop.
4. Turn on the projector. Most projectors have an auto detect function,
that will detect a video signal and auto configure the projector to
display that signal. If you have a laptop, you have to hit a function
key to activate the second display. Usually this is FN Key + F5 or one
of the F Keys across the top of the laptop keyboard. It looks like two
squares, one empty and one with something in it.
5. Adjust the focus, brightness, contrast, and color on the projector.
6. Aim the projector at something white. Try not to aim it at something highly reflective.
7. Step back ... Load up your favorite game or video ... and enjoy.
Your project should work, after following the above instruction.
unfortunately, infocus no longer makes or even carries parts for that model. you could try getting a bad one on ebay that has a different problem and swap the parts.
I called InFocus and was walked through several steps to determine if it was a bad cable or an internal problem. My InFocus unit would power up and stay powered up with no problem until I connected it to the computer using the analog computer cable (blue connectors). They had me try it with a different computer and then with the S-Video cable. Each time the InFocus unit powered down within seconds of connecting to the computer. The problem is internal. The unit had to be sent to InFocus for repair ($180). If the unit works with the S-Video cable then your problem is a bad cable.
