LG 42LC2D 42 in. LCD HDTV Logo
Posted on Oct 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Some channels on direct tv have a black rectangle
Some channels on my LG tv have a black rectangle box in the middle of the screen. How do you make this go away? Direct tv is my provider.
Anonymous
Level 2:
  • Expert 73 Answers
  • Posted on Oct 15, 2009
Anonymous
Expert
Level 2:
Answers
73
Questions
Helped
30507
Points
219
Either your tv or your directv receiver is on the text mode of the closed captioning function turn closed caption off and this will disappear.
Black rectangle in the screen and wont change channels
The rectangle is the set or the box if used in the closed caption area is set or TEXT is selected--turn that off.
Won't change channels: up or down? Direct enter a channel with the remote 03 and enter to see if it works that way.
Also need to know if you are using a box for signal.
Resolve the text issue first so you can clearly see the regular screen.
Let me know what happens and what you have tried.
1helpful
My 32 lcd tv a black rectangle apears on aprox,
If it is a large black rectangle that blots out the middle of the screen then you need to check your CC (closed caption) setting. Make sure the closed caption is turned off. I'm not up to date on the newer sets, but a lot of the older ones had more than one CC setting. One setting ran the captioning across the bottom, another put it in a big black box in the center of the screen. Most places didn't support the full text so all that showed was a big black rectangle on the screen. Since I'm not sure exactly what your rectangle looks like, this is my best estimate of your problem. Hope this helps.
6helpful
Black box in middle of tv screen
This is a background for text, even though you aren't seeing any text at the time. Since it covers most of the screen, it sounds more like a demo mode screen than closed captioning. Go into your setup menu and make sure that neither of those is selected. If necessary, restore the factory settings. I'm assuming that this is coming from the tv itself, and that you don't have a VCR, Tivo, etc. Good luck!
6helpful
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
4helpful
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
16helpful
I have a LG plasma T.V., model 42PB4D. Black box/middle of screen
Try this:
In the menu go to CC and set the TV to CC1 as this is a text box appearing for captions. Hope this works!
Using rooftop antenna through converter bos to RCA TV
Turn off the text box function of the closed caption decoder on the tv.
2helpful
Black rectangle in the middle of my screen
Turn off the text box function of the closed captioning.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
