Maytag MMV1153A Microwave Oven Logo
Posted on Oct 15, 2009
The emerson microwave suddenly stops working,no power supply.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 17, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1340
Points
6
Two microwaves, 3 service companies and 6 service calls later, I think I have the answer. My unit is a MMV1153BAB but I'll bet the problem runs throughout the Maytag line. The units are ship from the factory set up to vent to the interior. If your want to vent outside, the fan in the right, rear, upper coner needs to be repositioned. Tell the service tech to go to servicematters,com and follow the link for technicians and find service pointer K8178715 issued in 2007. My unit has now run 20+ minutes with no problem and no moisture buildup.
3 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 13, 2008
SOURCE: Emerson Microwave MW8119SB not turning on
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Anonymous
  • Posted on Dec 11, 2009
SOURCE: microwave stopped working all of a sudden. NO
http://www.partselect.com/repair.aspx?appliance=microwave&part=replace-fuse
Anonymous
  • 43501 Answers
  • Posted on May 17, 2011
SOURCE: My microwave stopped working suddenly, the fuse is
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
Have a cookworks microwave model AM821AHT-X2, only 6 months old and just suddenly stopped working properly,not heating up,timer and lights are working but no heat at all.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Check the fuse on the floor of the oven. find it near where the cord enters the box.
3helpful
3answers
I have a emerson microwave that has stopping heating, model #mw8119sb, please help me
Emerson may be able to tell you which part has failed but you may have to have the unit looked at be a small appliance repair person. Send Emerson an email to [email protected] with your model number and the problem you're having. If the unit is out of warranty, it may be cheaper to replace the microwave depending on what you paid for it. Keep in mind that the labor on any repair will be a minimum of $50 if you have to take it someone's shop, and that doesn't include the price of the part. Any part needed would be purchased from Fox International who's the part distributor for Emerson. They wouldn't know which part you need, however, because they're just a large parts store. Below is the link for Emerson's website.
http://emersonelectronics.ca/emerson/en/home/
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
4helpful
Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Microwave caught on fire.
I agree! That is an extreme hazard. Possibly due to over voltage of the power supply or faulty relay systems. Emerson is usually a cheaper brand anyhow. I would get the money back instead of exchange.
4helpful
Replace Emerson Microwave Ove Fuse
Most of the manufactory has put them in the back where the power cord comes in.
Microwave exploded.
Did it make a popping noise, like a .22 cal pistol? Probably one of the larger capacitors on the power supply blew up.
9helpful
3answers
Microwave stopped working all of a sudden. NO power supply. I tried placing at different places.But no use..I ddidn't see any problem before it stopped working..
the most common problem with microwaves is the door protection circuit blows a fuse. the door catches operate switch that if they do not operate correctly( normally after the door has been slammed). the good part is they place the fuse inside the casing. so remove the power open the casing( several screws) and check all the fuses in side.
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
