There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
For fixing computer automatically shuts down issue, you shall remove the
motherboard and reconnect all the connections. Take help of a hardware
expert while doing the task. The solution to fix computer automatically shuts down is to download and run a good and reputed Registry Cleaner software, use RegInOut to fix this problem.
I suggest try to check these things on your machine.
->Check if the machine is Overheating. ->Check which part of the machine is Overheating. ->See if the Fan of the machine is Running(Feel if the air vent of the machine)
Cause of Automatic Shutdown: -Memory -Hard Drive -Fan is not working
Most likely those are the cause of the machine keeps on shutting down unexpectedly.
I looked at all the settings that you are able to change on MY camera and no.... you can't.... I was wondering that too a while back and I had to just give up on that.... :D hahaha.... but I hope this helped....
At least it doesn't Atomically shut down. that's a bigger problem.
but seriously give us a clue. no computer actually shuts down automatically, you have to push something or set it up to shut down on a timer or something. you've given us nothing to work from.
some ideas: remove the virus, remove torrent programs that might be keeping the computer running all the time, reinstall the OS.
