Casio G-Shock GW500A-1V Wrist Watch Logo
Posted on Oct 15, 2009
I don't know how to turn off the automatic light feature on my watch
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Oct 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4639
Points
16
There is a button with an atomic time symbol below the face of the watch. Press and hold this button until you hear a beep and the light will go off. To turn it back on again, just press and hold that same button until you hear a beep and it will come back in automatically when you tilt your watch.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 03, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3390
Points
NO,JUST PRESS THE DOWN-RIGHT BUTTON ON THE WATCH REFFERED IN THE MANUAL AS BUTTON _D
Instructions for Eddie Bauer watch lg light up 3 eye 0058 CE
Here are some general instructions that may help you with your watch:
  1. To set the time, locate the crown (a small knob or button) on the side of the watch. Turn the crown to the right to advance the time, and to the left to go back.
  2. To set the date, locate the crown and pull it out one notch. Turn the crown to the right to advance the date, and to the left to go back. When you are finished setting the date, push the crown back in to secure it.
  3. The two small dials in the watch face are most likely used to track additional functions, such as a second time zone or a countdown timer. Refer to the watch manual for specific instructions on how to use these functions.
  4. To activate the light-up feature, press the button or knob on the side of the watch. This will cause the watch hands and dials to light up, making it easier to read the time in low light conditions. The light will turn off automatically after a few seconds.
Dec 15, 2022 • LG Watches
tip
HOW TO START YOUR AUTOMATIC WATCH
mcdevito75 here,The Automatic feature in your WATCH consists of a counter-weight attached to the MAIN SPRING by a gear that allows a SLOW but steady wind of your watch with the motion of your WRIST, ARM. Once, only in HIGH END watches, today almost all watch manufacturers have this feature in some of their models. Everyone who owns an AUTOMATIC watch knows, you can START your AUTOMATIC watch by WINDING THE STEM and you can continue to wind the stem with no end. This will at least START your AUTOMATIC watch and, this is true to some extent BUT, does this apply to my watch you ask?, Here"s how to tell if your AUTOMATIC watch will START with a few winds of the stem or not. ------- Very Simply, Hold your AUTOMATIC watch to your ear and wind the stem, if you hear a sound as though something is DRAGGING or the stem feels slightly stiff one way you wind the stem and you hear a clicking sound when you wind in the other direction, then you have the TYPE of AUTOMATIC watch that will start with a few winds of the stem, approx, 20 turns or winds. If on the other hand you hear nothing when you wind the stem and the stem feels very loose when turnning then you have the TYPE of AUTOMATIC watch that winds only with the motion of your wrist / arm, to start this type of AUTOMATIC watch, simply hold the watch in your hand and rock your watch back and forth, say from the 12 O"clock to the 6 O"clock, and or, Hold your watch securely in your hand a make circular motions with your hand, any movement to get your watches counter-balance to turn and thus wind your watch. Approx. 1 minute of this extra motion will start your AUTOMATIC watch, then simply wear your watch and your wrists / arm motion will keep it wound.
on Jul 06, 2010 • Watches
I have Relic VX3J 3 Eye - stopped working after 2 years.
If turning the adjustment bead does not result in a clicking then it is likely quartz. I am presuming it did not require winding. So if it clicks and comes back to life it is automatic (just wear it to charge it) if not then it is likely quartz. Most automatic watches can also be manually wound to charge. This is better for the movement when it is fully unwound, 10 full turns to be on the cautious side from flat. It is unlikely you can overwind good quality modern watches as they have a clutch to prevent over winding. cheaper watches may or may not have this feature.
1helpful
C9 champion digital alarm
Since you don\'t know how to turn it off, the alarm will give you simple instructions. Just stop pressing the buttons. Is there a symbol or an alarm or clock on any of the buttons?
May 10, 2013 • Watches
I have a brand new watch: Tag Heuer aquaracer automatic calibere 5 model WAN2110 and the date is not advancing (as it should every 24 hours). Any reason why?
You are actually supposed to be using a special case opener for this type of watch, however, if you want to open it, always remember, righty tighty, lefty loosy!
I am pretty sure those watches are water proof up to 3 ATM, so once you open that watch, just know, if you don't get the back put on tight, it's going to leak.
Good luck, i know you can do it. Oh, and if you have ever had the watch in for service before, there are ALYWAYS **** watchmakers who like to over tighten the watch cases. My husband is a watchmaker, and we have seen this hundreds of times. :)
1helpful
I love my Gevril Prime Minister Moon Phase watch. The two-franc Swiss coin fixed to the back, which is touted as a luxury feature, provokes two concerns. First, extra weight. I would always like my things...
Try putting something on the back to prevent contact with your skin.
I can think of few alternatives:-
1) self adhesive plastic.
2) paint it with polyurethane varnish
3) self adhesive baize.
1helpful
The background light comes on when placed in the vertical. I need to turn it off to save battery life
The Auto Light feature of your watch has been turned on. To turn it off, press and hold the button that is on the bottom right of your watch for about 2 seconds. In the upper right of the face of your watch is a circle with some text on it. There should be a down pointing triangle in the upper right of that circle. Below that triangle there should be a dark mark before you turn off the auto light. After you hold the lower right button down for the 2 seconds that dark mark should turn off. The Auto Light feature will also turn itself off after six hours to help you to conserve your battery life.
6helpful
Automatic light function.
There is a button below the face of the watch that has the atomic watch symbol on it. Hold this button down until you hear a beep and it will turn that function off. To turn it back on, press & hold the same button until you hear a beep.
7helpful
2answers
Second hand on my watch now goes in 5 second intervals
Check the instruction manual if you have one. Tag-Heuer watches move in 5 second intervals to let you know the battery needs replacing. A neat feature. Now you know that you have a real Tag!
Automatic backlight
PUSH AND HOLD THE MANUAL LIGHT BUTTON, SHOULD CHANGE TO AUTO MODE
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
