SOURCE: delete multiple pictures
The only way you can delete multiple pictures with this camera is to use the format function. This deletes all information including pictures and video from the card giving a totally blank card. You can set it to do this with internal memory also.
There is no function to selectively pick multiple images for deletion.
Hope this helps. Please remember to rate my answer. Many Thanks.
SOURCE: My kodak easyshare c813 camera but it wont turn on
Your problem is likely due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
SOURCE: kodak easyshare C813 screen
Hi, are you having issue on camera LCD screen that it will not show anything on the screen? Kodak Easyshare C813 has no feature to turn the LCD screen Off only Kodak Easyshare Z series and some M series that has a view finder that you can switch the LCD screen off and just use the view finder to save battery power.
You can refer to Kodak Easyshare Manual check this site http://www.kodak.com/global/en/service/publications/index.jhtml?pq-path=1398#otherDigitalCameras
For troubleshooting http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
SOURCE: kodak easyshare c813 cracked screen
Try to buy a new replacement form here: http://www.ownta.com/kodak-easyshare-c813-digital-camera-repairing-lcd-display-screen-replacement.html
SOURCE: How do I transfer pictures from my Kodak Easyshare
You can also go to an electronic dealer or even Walmart and purchace a card holder for your memory card you can remove the memory card from your camera slide it into the card and plug it into the USB port - Make sure you get the card reader for your memory card..
Copy
pictures/videos:
Press
the Review button, then the Menu button.
Press
^ v to highlight Copy, then press OK.
Press
^ v to highlight an option.
Press
OK.
Hope that helps
David
