Question about Canon PIXMA MX330 Multifunction InkJet Color Printer
Paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper.
    New Friend:
"paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper."
I am having the same trouble, what was the solution?
Posted on Aug 23, 2010
  • ryanpetry Aug 17, 2011
    Being this was a year ago, I doubt you need the help any longer; I am posted this to help others who might encounter the same problem. I had the same issue, and couldn't find the answer anywhere either. So what I just did was took the ink cartridges out, unplugged the unit and held it upside down, shook it a few times, and boom! There was a tiny piece of plastic that came out. Must have been laying in front of the roller that pulls the paper from the feeder and obstructed the paper from going through. I have a 2- year-old who thinks the printer is a dollhouse and plays with it all the time and must have put that piece of plastic in there. That's my guess.
  • kena walla Aug 21, 2013
    hey ryan,ken in myrtle beach,sc,usa,its aug 21st.2013 and i have same problem,gonna try what u suggested, i mean was working earlier n poof wants to feed at a angle n jam up..ps found a rubber band in paper feed,and got siccors and cut the rubber band,but still having poblem,soo,ill try ur idea,smilz,ken at the beam..ramsxx
I had this same problem . . . then I read someones suggestion to turn the printer upside down and shake it a bit . . . sounds odd but thats exactly what I did and it WORKED!!
Posted on Oct 04, 2011
    Problem Solver:
  • 5 Answers
FreeThinker1 solution worked! Try this before flipping unit over and banging it!
With access cover open,take letter sized paper, fold it in thirds or quarters, slide it into the paper feed at back of unit (normal paper feed direction) on the side that's obstructed and look in the unit to see where the paper enters. Then use card stock or thicker paper in reverse direction.
Posted on Oct 18, 2012
6ya staff
SOURCE:
Anonymous
SOURCE: paper feeds crooked
Sounds like a blocked paper path, paperclips , staples , bits of paper etc can drop into the sheet feeder entry and get stuck in the paper rollers.Look and see if you can see anything in there, if not try feeding a piece of thin card back through the printer from the front (ie in reverse of the normal paper travel) be careful and you may be lucky and drive out the obstruction, if not you will need to strip it down to investigate further
Posted on Feb 02, 2009
Anonymous
SOURCE: canon ip3300 paper feed not working properly
There is a small switch on the bottom left on the front of the printer that was selecting envelope feed instead of paper feed. Changing this fixed the problem.
Posted on Jan 15, 2010
Loca38572
SOURCE: Paper wont feed into printer no paper jam
In the comments section Blumm suggests pushing a piece of cardboard (like the back of a legal pad) through the feeder as far as you can. Turn the printer off and then on again with it in there. Pull the cardboard out and check for any foreign objects that have been pushed through.
It worked for many people including myself - I got a piece of plastic and it works wonderfully again!
Posted on Jul 31, 2010
SlickGnome
  • 7 Answers
SOURCE: paper won't feed properly and
There are a couple of possibilities. First is a little piece of paper could be stuck somewhere along the paper path and is causing one of the feed rollers to not grab the paper evenly, which will make the page twist on most of the models in this series, if you pull the paper out and take a flashlight and look up the feed path you will usually see anything in the feed path near/on the rollers at the top.
Another possibility is one of the feed rollers is old and worn out (If machine gets heavy use) and it will cause same issue.
Also light paper stock can sometimes be too thin for the rollers to grab properly and cause it to twist and slide around. This is usually more of an issue with gravity/drop feed printers but can also occur on front feed style too. Usually 20lb stock is good, but if thats doing it, you can try going to a 24lb.
Posted on May 06, 2011
Joed911
JDTec
  • 4338 Answers
SOURCE: Paper feed issues when there
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 19, 2011
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Paper won't feed properly and jams. the paper starts to feed then twists and jams.
May 06, 2011 | Epson WorkForce 600 All-In-One InkJet...
My inkjet printer is not feeding paper properly. Pages feed at an angle even if they are square in the tray.
I would check for little bits of paper stuck on the roller. Did you have a paper jam prior to this problem? Using a good flash light, look for, and remove any little pieces that you might find.
Oct 19, 2010 | HP DeskJet 712c InkJet Printer
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Kyocera 3900dn says paper jam in rear but no jam evident
Usually a printer doesn't lie when it indicates a paper jam, if you have checked as thoroughly as possible and no paper can be found. It is possible that the paper just isn't feeding and a printer will sometimes indicate a paper jam when paper doesn't feed. But if this isn't the case and a jam is indicated as soon as you turn the printer on, one of the plastic jam sensing actuators may be broken or hung up.
Aug 05, 2009 | Kyocera FS-3900DN Laser Printer
Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
May 11, 2009 | Canon LBP 1120 Laser Printer
Paper feeds crooked
Jan 31, 2009 | Epson Stylus 880 InkJet Color Printer
HP 1315 paper load and scan problems
I would perform a hard reset of the printer electronics and also reinstall the driver to see if the combination of these two procedures restores proper operation.
Sep 20, 2017 | HP OfficeJet k60xi InkJet Printer
Canon PIXMA MX330 Multifunction InkJet Color Printer Logo
1,461 people viewed this question
Clive
Clive
old marine
old marine
Ekse
