I have 3 usb ports( two at the back and one on the
I run Windows XP sp3 and I have an intel core duo 2.40 GHz. I have 3 usb ports( two at the back and one on the side ) and three devices: Microsoft webcam, HP printer and a Lexar Firefly 4GB. Most of the time only the webcam is plugged in and not necessarily in use.My usb ports stopped responding two days ago and only recognised my printer.
I read a thread on fixya which advised to disable the USB 2.0-enhanced host controller, by following these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
I did that and now both usb's at the back work but the side one is still dead. How can I get it to work again?
Also, when I plugged my webcam into the usb port at the back which had been dead but after follwing the above steps, works again, I got a message that it could work faster on another port, which I guess is the one I disabled. But if I enable it, the cam doesn't work at all. What should I do? The Lexar memory stick is still ignored on all usb ports.Thank you.
The flash drive works on another computer and on my laptop.It's the usb that has developed a problem.Not long ago I had some friends over and I plugged into the side port a mobile and then another flash drive ( Apacer ) whose plug was thinner than the one on Lexar. Could this have caused the problem? I have tried Microsoft's suggestios but nothing has worked. Everything was fine until a couple of days ago!
Also there's another thing that buffles me. My cam won't work unless I disables the USB2 Enhanced controller. And when it does work, it tells me that this device could work faster on a usb2 port and it says that one is available on my pc and it's USB2 2836. How can get round this? It's such a gloomy day here in Athens today!The first true Autumn day! Thank you so much for your time. :)The flash drive works on another computer and on my laptop.It's the usb that has developed a problem.Not long ago I had some friends over and I plugged into the side port a mobile and then another flash drive ( Apacer ) whose plug was thinner than the one on Lexar. Could this have caused the problem? I have tried Microsoft's suggestios but nothing has worked.
You can't post conmments that contain an email address.
Re: I have 3 usb ports( two at the back and one on the
Check to see if something else will work on the side port. It may not necessarily be a dead port. Just something you should know too; I used to work for Wal-Mart in the electronics department and they had to recall all their firefly flash drives because they had a tendancy to malfunction. Try using it on a different computer, it might just be a dead flash drive. I hope this helps your problem and I hope your flash drive didn't have anything too important on it :x
Microsoft® Windows® 7 Enterprise, Ultimate, Professional, or Home Premium (compare Windows 7 versions); Microsoft® Windows Vista® Enterprise, Business, Ultimate, or Home Premium (SP2 or later) (compare Windows Vista versions); or Microsoft® Windows® XP Professional or Home edition (SP3 or later)
For Windows Vista or Windows 7: Intel® Pentium® 4 or AMD Athlon® dual-core processor, 3.0 GHz or higher with SSE2 technology; for Windows XP: Intel Pentium 4 or AMD Athlon dual-core processor, 1.6 GHz or higher with SSE2 technology
These are the system requirements for the M-Audio Fast Track USB input. Be sure that you meet these requirements, or else upgrade your system to meet them.
MINIMUM SYSTEM REQUIREMENTS-FAST TRACK HARDWARE
Windows
OS: Windows Vista 32/64 or Windows XP (SP3) Home or Professional
CPU: Pentium 4 2.0GHz, 1 GB RAM, 1 native USB port
Mac
OS: OS X 10.4.11
CPU: G4 (native), 1 GB RAM, 1 native USB port
MINIMUM SYSTEM REQUIREMENTS-PRO TOOLS M-POWERED ESSENTIAL HARDWARE
Windows
CPU: 1.8GHz multi-core (Intel or AMD), 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
Mac
OS: OS X 10.5.5 or greater
CPU: 1.8GHz Intel multi-core, 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
The system requirements for Pinnacle Studio Ultimate 14
1) Windows® 7, Windows Vista® (SP2), Windows XP (SP3) operating system. 2) Intel® Pentium® or AMD Athlon™ 1.8 GHz (2.4 GHz or higher recommended) Intel Core™2 Duo 2.4 GHz required for AVCHD*, Intel Core™2 Quad 2.66 GHz or Intel Core i7 required for AVCHD* 1920. 3) 1 GB system memory recommended, 2 GB required for AVCHD* 4) A DirectX® 9 or 10 compatible graphics card with 64 MB (128 MB or higher recommended) 128 MB required for Red Giant Magic Bullet Looks Plug-in: Pixelshader 2 required, Intel GMA integrated graphics not supported. 256 MB required for HD and AVCHD* 5) DirectX 9 or higher compatible sound card. 6) 3,6 GB of free hard disk space. 7) DVD-ROM drive to install software.
Check to see if your system forfills the minimum system requirements.
Just about a month back I purchased a Lenovo laptop having Intel Core i3 processor loaded with DOS.
I then installed Windows XP SP3 32-bit and there is absolutely no problem whatsoever with the compatibilty. Also, all the device drivers for Windows XP are available on Lenovo support website.
So, there should be no problem to install and run Windows XP on this laptop.
This is your game's Minimum System Requirements: OS: Windows XP SP3/Vista SP2 Processor:
Intel Core 2 DUO E4700 (2.6 GHz) / AMD Athlon 64 X2 3800+ Memory: 1
Gb Hard Drive: 8 Gb free Video Memory: 256 Mb Video Card:
nVidia GeForce 7800 / ATI Radeon X1800 Sound Card: DirectX Compatible DirectX:
9.0c Keyboard Mouse DVD Rom Drive
restart you laptop and boot into bios, reset to factory default. again re-start and boot to windows check all hardware devices driver must be installed with no error.
Hi, Check your system if it meets the following requirements Age of Conan Required
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI
9800
Recommended
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek System Requirements
OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
Memory: 1GB RAM
Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD
Graphics
Sound: DirectX 9.0c Compatible Soundcard
DirectX: Version 9.0c or Higher
HDD: 8GB Free Disk Space
Network: Internet Broadband Connection Required
Disc: 6X DVD-ROM
Recommended System Configuration
CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
Memory: 2GB RAM+
Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
