When you import pictures into iPhoto there is a setting for deleting the imported pictures from the camera. Be sure to uncheck that setting if you want to keep the pictures on the camera after importing them into iPhoto.
To see the pictures (if any) without iPhoto, obtain a SD card reader (as little as $2 on Amazon) and plug the card from your camera into it, and the adapter into a USB port on the camera.
SOURCE: Took pictures with Olympus Stylist
It is possible that the memory card was damaged. This would be by coincidence. Just in case only the formatting is damaged you can try to format the memory card.
As far as reading the card is concerned, if the Mac has issues to read a PC format then it will not be able to read the card from your camera.
Jerry G.
SOURCE: Fugi S5000 2gb xd M+ Computer says it's not formated
Yes, it would appear that you solved your own problem. The Fuji S5000 apparently only takes the max of 512 mb card. I own a newer Fuji S700 and it works fine with a 2 gb SD card, but I haven't tried anything bigger. Your best bet is to see if you can exchange those 2 gig cards for 512 mb cards at the store where you purchased them, and then try the 512's to see if your pc will read the pics. Explain to the store what the problem is and they should allow you to make the exchange.
SOURCE: Nikon d100 tok several pictures and they are not on card
It sounds like it may have reformatted itself and if thats the case, they are gone. Some camera's have the option built in, then again, your computer might have done it when plugged into the card reader. I hope this can help shed some light on what may have happened, but sorry to say, if the memory card is now empty, chances are slim on recovering the pics.
