check the memory card remove the memory from the socket and clean them with a cloth insert it if the beep still occur change the memory card and also check the graphics section in the motherboard to verify insert a new graphics card suitable and switch on the system
control panel sounds and audio,audio you will find the necessary adjustments to makethere or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers hope this helps
you didnot wrote what the problem is, if tou were, solution should have been more specific. You can download update of the bios from the motherboard manufacturers website. That should solve general problem. If you provide some more details on the problem here, we can suggest other ways to solve.
The problem could be a failed electronic component, and no cooling remedy will solve the problem. When some components fail, they result in high heat conditions.
