Code 39
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
CauseThere are several causes of Code 39 errors:
- A required device driver is missing.
- A required binary file is corrupted.
- There is a problem with the file I/O process.
- A driver that is referencing an entry point in another binary file is unable to load.
Recommended resolutionReinstall the drivers for this device.
Uninstall and reinstall the driverUninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
You
may be prompted to provide the path of the driver. Windows may have the
driver built-in, or may still have the driver files installed from the
last time that you set up the device. However, sometimes, it will open
the New Hardware Wizard which may ask for the driver. If you are asked
for the driver and you do not have it, you can try to download the
latest driver from the hardware vendor’s Web site.
- On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
- Restart your computer.
- Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
I am sending you a copy of this information in the hopes that it will be of some help in your situation.
Cheers!
Ron.
