Canon DR-2050C Path-Through Scanner Logo
Posted on Oct 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm getting a vertical line down the center of my scanned image. I cleaned the rollers but the line is still there. Any suggestions?
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on Oct 14, 2009
Anonymous
Expert
Level 2:
Answers
50
Questions
10
Helped
17466
Points
151
Clean the **** glass.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
3answers
Why are pages scanning with lines running through them, but printing perfectly fine?
Try cleaning the rollers. Usually you have to remove the cartridge to get to the rollers that moves the paper.
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
Vertical line down the scanned image
Clean the glass with Isopropyl Alcohol. No solvents please
Black vertical line along left margin when using the adf to scan.
Check both the Fuser Unit and the Cartridge for lines . In any of the rollers are found with a line that means it needs to be replaced.
3helpful
Hp 4550 vertical line down center of page
From the service manual:
Vertical lines or streaks
 Check for a leak where light might be entering the printer.
 Check for circumferential scars on the photosensitive drum. If scars are present, replace the
drum cartridge if the line goes through all colors.
 Check for circumferential scars on the upper fusing roller. If scars are present, replace the upper
fusing roller if the line goes through all colors.
 Remove the imaging drum and inspect main charger or imaging drum for a contaminant, such as
a fiber, if the line goes through all colors.
CAUTION Do not expose the imaging drum to light for more than 15 seconds. The drum is light sensitive, and
exposure to light can cause permanent damage.
Vertical black lines
 The toner cartridge is defective.
 The toner cartridge is not seated properly.
 The fuser entrance is dirty.
 The fuser has scratches on it.
 This might be a repetitive defect. If so, the lines will repeat at a consistent interval down the page.
 The printer needs to be cleaned.
 There is a problem in the heating element.
Vertical white lines
 If white lines or streaks appear only in the black areas of the printed media, print several
configuration pages to clear the anomaly. If this does not clear the problem, check the sleeve
surface to confirm the defect, then replace the black toner cartridge.
 If white lines appear only in a particular color, try printing several configuration pages to clear the
error. If the error does not clear, check the sleeve surface to confirm the defect, then replace the
defective toner cartridge.
 There is a lack of toner or the toner cartridge is faulty.
 There is dirt in the laser path.
 The fuser is defective.
 A mirror in the laser scanner is dirty.
2helpful
Vertical lines when scanning using automatic document feeder...Glass is clean
It is not in the glass. More than likely it is in the rollers of the ADF feeder. If you open the cover of the ADF feeder you can see there are 3 screws (! is found under another small cover furthest to the back of the machine. Once these three screws are removed you can left the entire ADF feeder from the unit. You will then be able to clean all the rollers. Do not use alcohol as this will dry our your rollers and cause them to eventually crack. Just use soap and water to clean the rollers. Then reinstall the ADF feeder assembly back on the machine.
3helpful
Two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Vertical white lines in scanned image
Did you try cleaning the little glass strip where the documents go in? Lift the button panel and wipe the glass with rubbing alcohol and cotton swabs or lens paper if you have it. Mine does this sometimes when dust or white out or little bits of paper get stuck on the glass.
4helpful
Vertical lines through scanned images.
You should clean the small glass under the top lid. Chances are there is some white out or ink or mark on the glass. Look carefully because usually it is just a small dot>
old marine
old marine
ZJ Limited
ZJ Limited
