i have a problem with this cam ( LG E 500) it does not work. when i want to turn it on by clicking on the icon itselv it shows a message saying "no found webcam device, check your PC camera"
i have checked the drive and it is properly instaled. and i also update all programs and drives.i have a problem with this cam ( LG E 500) it does not work. when i want to turn it on by clicking on the icon itselv it shows a message saying "no found webcam device, check your PC camera"
AnonymousFeb 20, 2008
ı have the same problem with the camera. it has been only two mounths ı bhought this computer and it was deviced so muh. so what is the problem now? is that justice. fck them alll ı have the same problem with the camera. it has been only two mounths ı bhought this computer and it was deviced so muh. so what is the problem now? is that justice. fck them alll
I get the error message not found webcam device. check your pc camera, my pc is almost new and i don't what to do i try to connected but i dont understand really well the problem.
thanksI get the error message not found webcam device. check your pc camera, my pc is almost new and i don't what to do i try to connected but i dont understand really well the problem.
I recently discovered yet another problem with my LG E500 notebook. Suddenly the smart cam does not snap pictures or record video because of a "Stream read error" or because "Bitmap image is not valid".
I have already had problems with Blue Soleil built-in Bluetooth device, when on it makes an awful noise and it often disconnects my bluetooth mouse. So far my solution to that one was to get a usb wireless mouse.
Anyone with the same problems? Solutions???I recently discovered yet another problem with my LG E500 notebook. Suddenly the smart cam does not snap pictures or record video because of a "Stream read error" or because "Bitmap image is not valid".
By apllying the solution consisting of changing the options at the BIOS, it almost magically turned on.
It is this way because one of the reasons I read for the cam not working was that one of the windows vista actualizations overwrote the pre-installed driver, and that's because loading the default setup options solved the problem.
hurrayyyy!!!!!!!!!
actually, I HAD he same problem.
i dont know where i can reinstall the cam that i have and i have tried all these things and they have not worked at all i dont know where i can reinstall the cam that i have and i have tried all these things and they have not worked at all
i have the same problem. i have the e300 and sometimes it works sometimes it doesn't. ATM, it's saying that i don't have a webcam at all. o_O... i have the same problem. i have the e300 and sometimes it works sometimes it doesn't. ATM, it's saying that i don't have a webcam at all. o_O...
how do i turn on my web cam?how do i turn on my web cam?
AnonymousJan 23, 2009
I have LG RD405A , I installed the drivers which came with LG CD, but my webcam is not working. I want to know whether we have to install any software for that. I have LG RD405A , I installed the drivers which came with LG CD, but my webcam is not working. I want to know whether we have to install any software for that.
After trying all the solutions in the forums, I found a post in a forum saying that one guy hat the same problem and called LG and they told them to do this:
Shut down your computer Take out the battery Start the computer (with the AC/DC cable plugged in) press F2 fast....and then you enter in the "BIOS" Select "Load default values" in the last menu from the bios Save changes and exit Then let the computer start windows, and after it is started, turn off the computer again. Put the battery inside the computer Start the computer (with the AC/DC cable plugged in) And woooow!!! the webcam works again!!!
I could not believe it!
guys! it really works!!!!!!!!!!!!!!!!!!!!!1
try!!!!!!!!!!
i have also lg E500!!!!!!!!!!!! :D
My mail, [email protected]
Turning the webcam on is by using a program to turn it .. if you have windows live messenger installed, you can check the properties of the camera by going Tools>>Webcam Settings ... and the camera should turn on .. if not then you have problem with the driver .. reinstall the driver to solve it
I had the same problem and, by apllying the solution consisting of changing the options at the BIOS, it almost magically turned on.
I have done all the things that might help to fix my lg e300 smartcam but none of them worked i think lg should do something about this...they can;t just let those cams die after several days.....
Try reinstalling your webcam drivers that came with it. If you do not have them, you can try to download them from the LG website or use a driver finder program.
i think your web cam its to low compare to vista bec. vista needs high specs i think you need to change your os and change to windows xp
i hope i can solve your problem
http://download.notebook-driver.com/driver/lg/E500/Vista/LGSmartCam.zip
at this location ya will find the driver for vista and just reinstall the camera ...it has to work ...probably it came with a xp driver and ....
Hi please try to reinstall the software for your webcam.. note...first uninstall the software then reboot system then install the software then reboot again then connect the cam on your laptop... Please rate.. have a nice day...
Thanks a lot for posting this.
Today my LG E500's Smart cam also stopped working after my battery was down too much. Didn't know what to do. And I didn't know about this Fn+F10 combination for the webcam.
My webcam works now after activating it by Fn+F10. However, I don't know what made it stop functioning.
Thanks any way but i found the poblem. cheers! Kylie
thanks
hurrayyyy!!!!!!!!!
My webcam has stopped working. LG E 500
how to turn on webcam
I dont Know how to switch my webcam on
I even reinstalled my whole computer, but my smart cam doesn't work! LG e500
I only get the message: not found webcam device. pleace check your pc camera
