Question about Bunn NHB Coffee Maker
My bunn coffee maker is leaking from the top where the water is poured into. It is leaking out of the bottom of the storage unit. A slow drip but I put a towel under the coffee maker and after a while it is soaked. what do I need to do
    New Friend:
  • 34 Answers
You need a new one.
try this link. hope it will help you with your problem.
http://www.coffeemakerwizard.com/4-cup-coffee-makers.html
Posted on Feb 01, 2010
Sent it back to bunn
Posted on Oct 15, 2009
6ya staff
SOURCE:
Bad leaking bunn commerical VPR pour-omatic
You will need to replace it, parts are not made for repair except under warranty.
Nov 30, 2016 | Bunn Coffee Makers & Espresso Machines
Bunn coffee maker leaks
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Jun 17, 2014 | Bunn VPR Coffee Maker
How do I fix my bunn #053213cs from leaking from the bottom
Aloha, ukeboy57
Jun 04, 2014 | Bunn VPR Coffee Maker
Water leaks from the top of the right side of commercial coffee maker
Aloha, ukeboy57
Apr 03, 2014 | Bunn VPR Coffee Maker
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
Bunn coffee maker only gives half a pot of coffee
Aloha, ukeboy57
PS, Check the pots in the office. Make sure they are all the same size. Decanters come in 3 sizes; 10 cup, 12 cup (standard), and 3L (3 litters). Check the decanter brand as each brand is a bit different in size. All metal decanters are usually very small (8 cup). What ever size you use, just make sure they are all the same.
Mar 08, 2013 | Bunn VPR Coffee Maker
My bunn coffee maker is just dripping when it is making coffee. Then the next time it makes it just fine.
Hello, I am wondering how long between times you are stating, as most Bunn commercial units, stay heating 24/7, and if water is not poured into the machine every couple of days, they will evaporate off water that is held in the tank. This drop in water level can cause short brewing, slow brewing, etc.. as the unit relies on a vacuum or suction to brew properly. You could also have a leaking tank gasket, or brew tube gasket, and it is seeping air into the tank, breaking the vacuum/siphon action, and then seals with water, or expansion at other times. Another cause would be scale build up, and pieces are floating in the tank blocking the flow of water, or your spray head may be clogging/clogged, which minor cleaning should take care of the sprayhead, and tube, or a major cleaning necessary for the tank.
Hope that helps, and thank you.
Mar 04, 2009 | Bunn VPR Coffee Maker
Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Jan 12, 2009 | Bunn VPR Coffee Maker
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Sep 05, 2008 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
708 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
Marvin
Marvin
littlechum55
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
