If it's not charging and your batteries are still good then more than likely the unit is shot. You can try cleaning the contacts on the unit and your batteries and see if that helps.If you know someone with a universal charger try your batteries on that to make sure it's not them that's the problem. Check ebay for a used one at a cheap price. This is not a fix you can do unless your a techie and it's not worth sending off to Ryobi for a factory fix. i just replaced my panasonic charger for the same reason, but i had it for 10 years.
