I think the easiest way would be to fit the SD card into a USB adaptor and plug the adaptor into the USB port of a computer. If you computer doesn't have a USB port, several printers have them and you can access that port when the printer is linked to the computer. Some printers will even take the SD Card direct! Once connected the Card will be just like a drive. And you can copy the MP3 files to your computer, then import them to the MP3 player.
USB SD Card adaptors are not expensive and can be found on Amazon.
Scanning is not possible thru the parallel port. You must use the USB1.1 port in order to use the scanning feature.
The parallel port is only used for printing.
If you hook up the machine with a USB cable you can print and scan using USB. This includes color scanning.
Thank You for using Fixya.
First, do you have the full-featured version of the software installed (installed on the computer before connecting the printer to the computer)? Second, do you have the all-in-one connected to a print server or USB hub? These can block the two-way communication needed for scanning. Try a direct connection. Also try a new USB cable and a different USB port (if you have any signal loss issues, it matters more with the scanner).
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Try changing the LPT port mode in the BIOS- there should be like SPP, EPP, ECP. As I recall there are different drivers for USB and Parallel and I don't think Serial is supported. If you installed HP drivers, Uninstall and use the Windows drivers.
If you have it connected by a CAT5 network wire, then the answer is no.
if you are using a usb 1.1 port on your computer to print to it, then that port is a slow port. I would recommend getting a faster 2.0 usb adaptor and using that port. It will print a little faster.
The issue which u r facing is" Communication issue" Make sure u have installed the lexmark printer software...or else download it from the lexmark website(lexmark.com)..choose the s\w for ur operation system( Xp or vista(32bit or 64bit))...
---------------------------------- If s\w is installed...
Check the USB cable..try different port... Clear all the docs in the printer folder... Remove the power adaptor and replung..restart computer..
When u unplug and replung the usb cable doesn ur computer give a pop up "found New hardware" ?
U can also try... Uninstalling the s\w....disconnect the USB cable..reinstal the s\w and connect the cable when it prompts to...
