Mitsubishi WS-65611 65" Rear Projection Television Logo
Posted on Oct 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MODEL WS-65611 TV DOES NOT RESPOND TO REMOTE. HAVE REPLACED BATTERIES AND RESET THE TV. REMOTE LIGHT WORKS.
Anonymous
Level 2:
Scholar:
  • Expert 120 Answers
  • Posted on Oct 13, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
120
Questions
0
Helped
44204
Points
302
Is your remote one of the "universal" ones that allows you control multiple boxes?
If so, be sure you are selecting the correct input (TV, DVD, AUX, SAT...etc).
It's also possible that you will have to reprogram your TV to accept the remote's input. This can happen even if the TV and the Remote were sold together. Check your TV/remote manual for the syncing instructions and associated codes.
TV will not respond to/recognize remote. I have
Check On the Menu Setup for On/Off Remote utility Maybe your Remote signal is off on the TV Set...
tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
tip
Bypass Mitsubishi WS-65611 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65611 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65611 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Not responding to remote,volume maximizes itself
this tv is known for the key board buttons geting stuck on . you can take the front panel off on disconect the key board to see if the remote works.
Mistsubishi HDTV 1080 Model WS-65611
hey there! good thing you posdt back. i dunno what happend earlier but that wont stop us would it. haha
anyway right,
have you tried changing your remote? it may sound odd but your tv may be fine and the remote is causing your tv to be like that.
you should try changing the remote first ok! cause probably a diode is messing the wat your tv should work.
tip
Download Mitsubishi WS-65611 HDTV Manual
Have you misplaced your Mitsubishi WS-65611 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65611 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
tip
I hope that helps.
on May 04, 2010 • Televison & Video
2answers
Mitsubishi WS-65611 power and volume problems
when it shuts down Try pushing the input and menu buttons together on the set it self and hold them both in for 8 seconds.and see if the LED blinks a diagnostic code.
tip
I hope that helps.
tip
I hope that helps.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
