Some toshiba laptops have trouble with the touchpad locking up. I have tried using a wireless mouse and it has helped whenever the touchpad locks up. to unlock (I'm assuming you mean log in) you can click space instead of using the mouse.
Are you sure it is locked? most touch pads dont have a lock feature on them.
Do a small test for me. Plug in a USB mouse and see if everything works as expected. if everything works then i suspect your touch pad has failed. If you order a new palmrest from ebay or another source you can replace without too much difficulty.
The palmrest is easy to change out. Have done a few.
1. Check to be sure your "Number Lock" or
"Function Lock" keys aren't lit. These can lock out certain parts of
your keyboard. If either of these is lit, press them to unlock the
locked portion of your keyboard. These can be found at the top right on
a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your
computer. This will only work if your computer isn't frozen. If your
mouse doesn't move, press the power button on your Dell until the
computer turns off. Press it again to restart. If the issue was lack of
memory or a locked program, this will unlock your keyboard. Continue to
Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over
and sliding the battery release latch. Slide the battery out and
replace after one minute.
Have a good one!
Step 2
Save
Step 3
Step 4
Remove
the battery if you're using a laptop by turning the laptop over and
sliding the battery release latch. Slide the battery out and replace
after one minute.
hi
your track-pad mouse has a horizontal bar-shaped button above it with an orange light next to it, try pressing that button. The light should turn white and your mouse should begin working again.
this might be a problem with the mouse lock.. check ur mouse lock button just above the mouse pad. if its locked, unlock it & try again.
if its not locked, then go to device manager via right clicking My Computer, properties select mouse device & expand the tab uninstall the mouse, dont worry it can be done without mouse. now press the windows key from keyboard, and restart ur system via pressing Start key, +u, +r for windows Xp & for Windows Vista, press ALT+F4 then select restart.
After ur machine boots up, it will automatically detect the mouse & reinstall the required drivers. its done
if u like my post, pls rate me.. i really need some good ratings.. Thanks
