Your TV doesn't have video output on either HDMI or Composite video. (There are a few TVs that do have a video out but often that is only available for some input/output combinations. You would need to check the manual but the PC input is usually not available for the video output.)
You could get a VGA to composite or component video converter and direct the signal to your new TV from your PC. One example of the first converter is here: http://www.cablestogo.com/product/29548 . An example of the VGA to component video is here: https://sewelldirect.com/audio-authority-vga-to-component-pc-to-hdtv-converter.asp . There are other models available. A few VGA to HDMI converters also exist. However, since those need to convert an analog output to digital, they are more expensive.
I hope this helps.
(A few VGA to composite cables exist. They will not work for your purpose. They are designed to connect projectors with RCA ports and understand the VGA RGB signal to a computer.)
Make sure you are on the correct input for hdmi on the TV through it's remote. Then look to this link below for direction on how to get your laptop to display out, instead of its LCD screen:
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
If there is a VGA output or a HDMI output then you can buy the VGA to HDMI cord at most electronic stores, just check the resolution compatibility with the TV, but it should work, good luck.
The best way is to get a s-video converter to connect your round s-video computer output to your HDMI port on your tv. This is the best you can do according to your laptop connections. You will need a s-video cable, HDMI upscale converter box and HDMI cable.
The other way is to plug a VGA cable to your tv VGA port if you have one.
VGA to HDMI is also possible with a converter. A standard VGA cable with a HDMI plug on the other side will not work because your computer sends out an analog video signal and HDMI is digital only.
Interfaces1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Microphone - Input - Mini-phone 3.5 mm , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 3 x Hi-Speed USB - 4 pin USB Type A
The above interfaces are in your laptop. There is no S-cable or HDMI interface. If your TV have VGA port you can connect your TV to the VGA port in laptop. This will alow you to convert the TV as monitor.
Your laptop will need a HDMI output or a DVI output for HD video. If your laptop only has a VGA out the your tv will need a VGA or DVI input. You could use a vga to dvi adapter if your tv does not have a vga connector. They do have a DVI to HDMI adapter but there are a couple of problems with that. One you will not get the sound and the TV will only obtain sound from HDMI cable when connected that way and Two the TV will have problems processing the signal from the computer due to the HDMI will only process the HD signals at certain formats and the computer video can send out many different signals. I tried and I could not get my tv to process the signal so I got a video card that has a HDMI out and my blu-ray player works great.
