We just bought an Insignia NS-LCD47HD-09 47 in. LCD TV two days ago. We are enjoying picture quality and for our immediate needs it has decent connections. Problem is that after watching it for a while (between 20min and 2 hours) it just shuts off. I am torn between taking it back and getting different manufacturers tv or having them just replace it. My wife is very upset and doesnt even want to deal with it. Can you offer some guidance as to which would be best approach? Thank you, John
Most modern TV sets don't usually have a separate fuse. Most have a safety cutout (Sometimes a fuse) soldered on to the main power inlet electronic board. Its inside the TV and will require the back to be taken off it. Make sure its unplugged before you do anything!
It May be a Simple fix to some people. But it could be a multiple things. Some capacitors inside could be bad or one of the boards it's self First go about by checking for bad capacitors and swap them out if needed. If that does not work its just about time to scrap it because for any of the boards inside could cost a hundred or 2 hundred bucks and you can just buy a new one.
I think your insignia is set for SHOP mode instead of HOME mode. I changed mine to HOME and it's working fine now. Press your menu button and then scroll down to setup. You're looking for Plug and PLay which should be the very first choice. If it's greyed out as mine was you'll have to change your imput from HDMI to TV in order to get to the P&P. Once you're in the Plug and Play your first choice is language. The second should be SHOP or HOME. Make sure to select HOME. You can skip scanning for channels. This fixed my problem with the blue light. The store uses SHOP so if someone plays around and changes something, all they have to do is shut off the TV and turn it back on. Please let me know if this works.
A variety of remote control codes can be found at InsigniaProducts.com; just click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
Available parts for your TV can be purchased here. Alternatively, in-home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Nothing at all? Does the screen seem to go from dark black to a lighter shade of black?
If the screen appears to stay on the darker shade of black then it is broken, and needs to be sent for repair. ( ie the screen isnt powering on when the tv is and there is nothing you can do without opening it.
You might try unplugging all cables and leaving it off with no power for a day This is in effect performing a factory reset.
and this may sound stupid and patronizing but is the TV being taken out of standby mode and actually switched on?
